Pinion Bearing Help!!??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DogandTACO, Dec 3, 2016.
  1. Dec 3, 2016 at 11:30 AM
    DogandTACO
    DogandTACO [OP] Well-Known Member
    Trent
    05 Silver TRD Sport 6in lift Demello Front Tools in the rear
    6in lift, Demello Front bumper, 34in duratracs
    I have an 05 Tacoma Trd Sport 2wd on a 6in lift. All my issues have started after I re geared. It has been in the shop 3 times since then to have the pinion bearing replaced because it keeps frying itself. lat time it went in the replaced the whole gear set and a week later the issue is back. I have no clue what is causing it to fry. we have change the drive line angle reduced the vibration but it keeps burning out any ideas?
  2. Dec 3, 2016 at 11:43 AM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Get your money back and go somewhere else? Sounds like whatever they did wrong the first time they keep doing. Do you have a factory service manual? Maybe they're improperly torquing the bearing.
  3. Dec 3, 2016 at 5:20 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    Find somebody who knows how to do it correctly.
  4. Dec 3, 2016 at 7:05 PM
    RS218
    RS218 Member
    Yakima WA.
    08 Taco 4x4 access cab
    DB 6" lift,33" tires,18" wheels,4:88gears,auburn posi in back
    I agree a differential has a lot of torque on it & if you don't know what your doing, it can go bad real quick, I re-geared my truck,did the research & drove 150mls away to have the best do it & no issues, just be really picky
  5. Dec 4, 2016 at 7:05 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Clearance is to too tight it has a crush sleeve that sets the clearance it has been crushed too much probably been that way from day one.
