Pinion seal leak?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MountainManGuy, May 11, 2022.
  1. May 17, 2022 at 10:14 AM
    saint277
    saint277 Vigilo Confido
    off roads have a larger diff then other models, so take more fluid. If you polish that flange piece it should be fine, they usually look worse than they really are.
  2. May 17, 2022 at 10:21 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Run your finger across the seal area, if you can not feel the groove, then it's fine. Polish it with some emery cloth clean it up and reinstall.
    The grayish area is an area to inspect closely as well... this is an indication of corrosion... if you feel pitting in this area, and you can not polish it out you will need to replace it. This pitting will ruin your new seal extremely fast. Think of it as sandpaper on that nice new seal lip.
    Also, as @saint277 mentioned, you have an 8.75" rear diff. Not the 8.0". So more fluid is required.
  3. May 17, 2022 at 10:27 AM
    MountainManGuy
    MountainManGuy [OP] Well-Known Member
    Colorado
    2019 Toyota Tacoma TRD Off-Road DCSB
    Gotcha thanks man
    Makes sense. Thankfully there was no pitting and it cleaned right up. Unfortunately, I could definitely feel the groove there which still has me confused. I feel like that should happen after 100k, not 45k. Luckily the leak was really small so if it does do it again I'll have plenty of time to get it fixed. Also from what I've read it's a cheap part so no huge loss here.
    Speedfreak[QUOTED] likes this.
  4. Aug 28, 2024 at 1:34 PM
    Crayzemixer
    Crayzemixer New Member
    LJay
    Tacoma 4DR, Off-Road, 3rd Gen 2018
    Prinsu Rack, 285R16 Wildpeaks, C4 Sliders, RCI Skid, CVT RTT, 5.29's
    Running into the same leak right now. Hopefully the replacement and bypass will be able to fix the issue before spending $600 for seal replacement and flush. About 60k post regeared to 5.29's fyi
  5. Aug 28, 2024 at 1:38 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^Seal is easy to replace as DIY job if you have a vernier caliper and impact wrench.
  6. Aug 29, 2024 at 8:13 AM
    Northerntaco69
    Northerntaco69 Well-Known Member
    2023 TRD Offroad 6MT dcsb
    Trd pro grill, blackout overlays, black tailgate inserts
    Check your breather. If you play in the mud and it looks like you do. It can get clogged and make pressure in the housing.
  7. May 7, 2025 at 6:05 PM
    Chairmanmeow66
    Chairmanmeow66 Well-Known Member
    2020 Tacoma TRD off road
    Same situation for me slight leak post 10k 5.29 regear did you by chance have a low hum or drone noise when on throttle at higher speeds 70-75mph? I’m trying to figure out if this bad pinion seal is causing the noise
