Pinion seal replaced...diff temp?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gtrotter07, Jun 15, 2023.
  1. Jun 15, 2023 at 12:17 PM
    gtrotter07
    gtrotter07 [OP] Well-Known Member
    2007 Tacoma reg cab 4x4 on 37's; 2021 TRD Offroad, 6 speed
    37's,lockers, bumpers, bobbed etc.
    Hey all, I recently replaced a leaking pinion seal on my rear 8.4 diff. Leak is fixed, but I'm curious what temp is kosher on the diff, and what inch lbs you guys saw for drag? My drag before replacement seemed "loose", and once I replaced I got it at approximately 12 inch lbs. My diff temp is floating at 155-160 running 65 for 30 miles, with an ambient temp of 90. Diff has 4.88 gears, Detroit locker and I'm running 37x12.50 tires. Gear oil is 85w-140.
  2. Jun 15, 2023 at 12:29 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Those temps sound about right with 37s
    TnShooter likes this.
  3. Jun 15, 2023 at 1:36 PM
    gtrotter07
    That's what I was thinking, but I didn't measure temp for a baseline before hand. I was worried I went too tight on the bearing and was creating excess heat.
