Pinion Seal
Discussion in '1st Gen. Tacomas (1995-2004)' started by timweaver, Jun 3, 2011.
  1. Jun 3, 2011 at 6:40 AM
    timweaver
    timweaver [OP] Member
    Tim
    Kansas
    98 SR5
    Hello,
    I have a 98 Tacoma 4X4. I recently noticed a pool of oil under my rear end. I am assuming that its the pinion seal. She has about 250K on her, so this isnt too shocking to think the seal needs replaced. So I go to the autozone website to see what a seal is going to cost. I found 2 different ones for my truck. One says its for an 8 1/4 inch ring gear, and one says its for 6.7 inch ring gear.
    Is this simply the differences between 2 wheel drive and 4 wheel drive rear ends? If not....how do I know which one I need to get? It is wisest to pull the old one out and take it with me?
  2. Jun 3, 2011 at 6:40 AM
    timweaver
    Tim
    Kansas
    98 SR5
    Crap.....now I found one for an 8.8 inch ring gear.
  3. Jun 5, 2011 at 2:58 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    The seal for the third member right? If you don't have the locking diff I believe yours is the 8.4 diff. I just used rtv grey instead of the paper gasket.
  4. Jun 5, 2011 at 11:27 AM
    Robm
    Robm Member
    Rob
    Seattle
    02 Xtra cab SR5
    Ome 881 Coils and struts
    Is it coming from the pinion or were the third member bolts into the housing? If it is the later just use RTV, I use The Right Stuff by permatex, works awesome and is way better than any paper gasket. If it is the pinion seal make sure you get a good seal like a national seal or direct from Toyota. As far as what you have if it is a 4wd without trd locker than it is the 8.4.
