Pinion seal
Discussion in '1st Gen. Tacomas (1995-2004)' started by Howard Dalton, Jun 17, 2017.
  1. Jun 17, 2017 at 1:05 PM
    Howard Dalton
    Howard Dalton [OP] New Member
    2002 Toyota Tacoma
    My pinion seal is leaking I replace with the right seal. It shows three different ones I got the smallest one and it fit the shaft that slide into the rear end up by the collar. It leaks more now than it did before. Do I not have it on far enough or is the shaft worn out?
  2. Jun 18, 2017 at 7:03 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    For some Toyota parts its best to go to the dealer, they can look up your vin and get you the proper part, abet at a ridiculous price usually.
  3. Jun 18, 2017 at 8:32 AM
    tacopablo
    tacopablo Well-Known Member
    Québec
    2002 tacoma 2.7l
    I just did the procedure myself. Went to the dealer and gave them my VIN, got my parts for 30$. I hammered the seal with a socket until I think that was the bottom. It has to be square with the housing. Mine went a little deeper.
  4. Jun 18, 2017 at 10:01 AM
    gearcruncher
    Canadain bumper technician
    Considering you own a 2002 Tacoma and most likely higher mileage , you may want to add a speedy sleeve to give the seal a fresh surface to run on . Not saying your pinion shaft is wore out but it is a highly common problem
  5. Jun 18, 2017 at 10:51 AM
    Howard Dalton
    2002 Toyota Tacoma
    I'll go to Toyota and get the proper part.
    Where would I get the speedy sleeve and does it just slip over shaft
  6. Jun 18, 2017 at 11:00 AM
    gearcruncher
  7. Jun 18, 2017 at 11:15 AM
    Howard Dalton
    2002 Toyota Tacoma
    Thank you very much
