pink radiator fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jrider636, Jul 1, 2010.
  1. Jul 1, 2010 at 2:05 PM
    jrider636
    jrider636 [OP] Well-Known Member
    justin
    tally,fl
    08 tacoma prerunner
    i was told the stock fluid eats away at the heads and other internal parts. should i change it to prestone? thanks
  2. Jul 1, 2010 at 2:07 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    if it did that, i hardly think they would put it in there and not have a maint. schedule to change it out....
    the issue is when you mix regular (green) and dexacool (pink), i think
  3. Jul 1, 2010 at 2:19 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    The pink radiator fluid is the toyota super long life coolant. The change interval for it on the tacoma is 100k miles. I've read that all +05 toyota vehicles use it. If it were bad for them, then that would be a whole lot of vehicles with corroded engine parts. If you mix in other types of antifreeze that would probably be bad for it.
    Who told you it would corrode the engine parts and why?
  4. Jul 1, 2010 at 2:22 PM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    You got some bad info man. Our trucks use the super long life pink coolant. It should be flushed out around 100K miles. Don't use anything but OEM pink coolant.
  5. Jul 1, 2010 at 2:27 PM
    The_Hodge
    SC
    well there ya go....so if there's no difference, why the pink?
  6. Jul 1, 2010 at 2:37 PM
    afd23a
    The Dynamo of Dixie
    Here's a not very informative quote from toyotaownersonline
  7. Jul 1, 2010 at 3:16 PM
    zanodave
    zanodave Well-Known Member
    so il
    07speedwayblue
    Is it possible that Toyota just wants us to by their products?
  8. Jul 1, 2010 at 3:24 PM
    bearing01
    bearing01 Member
    San Diego
    4x4 TRD V6 MT
    The pink stuff is organic acid based which provides superior protection. It etches and creates a protective layer on the engine metal similar to how Aluminum has an aluminum-oxide protective coating (that it self generates) to prevent corrosion. When you add green-goo silicon based antifreeze you are relying on the silicon to "paint" the metal surface with a protection layer. As green goo silicon based antifreeze ages the silicon can drop out of solution and create a sludge and abrasive. It therefore has a shorter life.
    Stick with dealer pink antifreeze. It's not the same as GM's Dexcool. Dexcool has created many problems in GM's, especially when you put it in older engines with mixed metals - like say having a brass heater core and aluminum rad, head and cast iron block. The most reactive metal in the mix will get corroded away if there is air in the system that has Dexcool in it.
  9. Jul 1, 2010 at 3:33 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    I use Green in everything.
  10. Jul 1, 2010 at 4:51 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    I prefer the green as well. It's been around for ever and a day, and I have not been shown any evidence that the pink is better. Just Toyota marketing hype which says only, it's better because we said so and put it in when you bought the truck.
  11. Jul 1, 2010 at 5:05 PM
    Floki
    Floki Old Sheepdog
    St. Louis, MO
    2024 TRD Sport
    Mud on the tires
    I usually keep a vehicle 5 to 7 years, and drive around 6K miles a year. So, I'm not worried about any of this pink vs green stuff.
  12. Jul 1, 2010 at 5:38 PM
    bajaracer
    bajaracer Well-Known Member
    Charly
    Chandler
    05 PRERUNNER DBLCAB SPORT 4.0
    AEM DRY BRUTE FORCE, FLOWMASTER 50 SERIES, 285/70/17 BFG'S AT KO2'S MOTO METALS 17X8 885's with 5100's LOUD STEREO
    Im am considering changing the coolant bc i dont know if the previous owner did. I bought a gallon of the pink stuff, isone enough? Do i need to mix it with purified water? Shoud i use 2 gallons? What about adding REDLINES Water Wetter for extra protection? Cliams to loweer temps by 20 degrees.
  13. Jul 1, 2010 at 5:58 PM
    bearing01
    bearing01 Member
    San Diego
    4x4 TRD V6 MT
    redline water wetter won't make the engine cooler. It may help say a Corvette engine that has fundamental issues of running hot. Water wetter is only a surfactant to help reduce the water's surface tension and keep it in contact with the surface. It is commonly used in race cars that use straight water without antifreeze. Antifreeze has its own surfactant built in. The thermostat is what controls temperature.
    read these:
    http://www.gates.com/downloads/download_common.cfm?file=MOTORCoolantFeature.pdf&folder=brochure
    http://www.search-autoparts.com/sea...estandard//motorage/162005/156227/article.pdf
    My VW had "lifetime" OAT based pink antifreeze. When the car was 7 years old I decided to change the water pump. The antifreeze came out like brand new. With OAT antifreeze you need to replace the antifreeze when you add a new metal part to the system, so there will be sufficient chemicals present to protect the new non-protected part. Besides, always a good idea to not put back old fluids.
  14. Jul 1, 2010 at 6:08 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    i think that we should stick with the coolant that comes from the factory. i had some leaking problem but thats only because of my radiator cap and asked around, and not stealership people, but others on this forum and such and the conclusion i drew was that we run really good coolant and thats how i am going to keep it.
  15. Jul 1, 2010 at 10:48 PM
    afd23a
    The Dynamo of Dixie
    I bought 3 gallons to do my 4 cyl when it hits 100k. I'm not sure how many the 6 cyl takes, but it's probably 2-3 gallons. Check your owner's manual to be sure. If you're using the pink stuff from Toyota, it's premixed so don't add water. If you bought the red stuff, then it is not premixed and requires dilution. The pink stuff is what is recommended for our trucks.
  16. Jul 1, 2010 at 10:51 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    I run pink in my supercharger intercooler, and green in my normal coolant system. This way if I ever have a leak I will know where it is coming from.
  17. Jul 1, 2010 at 11:08 PM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    Haven't there been warranty issues when the coolant wasn't pink?
  18. Jul 1, 2010 at 11:10 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    pink.....i like a warm pink center. just like her "insides" lol
  19. Jul 2, 2010 at 12:08 AM
    Hondarider08
    Hondarider08 "That's what she said..."
    Justin
    Logan, UT (Originally Pocatello, ID)
    05 Tacoma TRD
    Leveling kit, K&N drop in, and a Loud Ass Stereo :)
    From what I've hear, I couldn't think of any reason why they would put bad antifreeze in our vehicles. I've heard that the pink antifreeze is a non-petrol. based and wont harm the animals if they get into it. I'm pretty sure it's pink because of the treehuggers now, not because of the fact that green was bad antifreeze. My motto is: "if thats what they put in it with a 100,00 mile sticker, then thats what I'm going to put in it for the next 100,000 mile sticker." :)
  20. Jul 2, 2010 at 12:30 AM
    005Tacoma
    005Tacoma Well-Known Member
    Thomasville, Georgia
    2005 Toyota Tacoma
    I think you guys should upgrade to that new "clear" blood they are giving people in exchange for their "red" blood. Its been said that it DON"T stain your clothes when you cut yourself and get it on your shirt or pants.
