Pioneer 4400bh and Galaxy S2
Discussion in 'Audio & Video' started by SNJTacoma11, Jan 20, 2013.
  1. Jan 20, 2013 at 3:48 AM
    SNJTacoma11
    SNJTacoma11 [OP] Well-Known Member
    Runnemede New Jersey
    2011 Tacoma Double Cab 4x4 Super White
    Rough Country 6" Lift 17" M/T Revolvers 35" Nitto Mud Terrain Cold Air Kit
    Hey Guys,
    So i just installed a Pioneer avh p-4400bh....love it got get some new speakers now but anyway.... I have an android phone no iphone. Can this be connected to the radio using same cable but with adapter? Or only way music playing through it is via bluetooth? If that way i see no album art?
    Tried contacting Pioneer but no answer ......unit is compatible with my phone but not dure if there is a cable out there or what????
    Thanks
  2. Jan 20, 2013 at 3:58 AM
    rickmeseke
    rickmeseke subaru of america
    Ricky
    Brunswick, GA
    a white truck
    im not familiar with the exact model but a usb cable you charge your phone with or aux cable should do the trick (assuming that model unit has them)
  3. Jan 20, 2013 at 4:10 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    I do not believe you can stream music the the HU using BT. I may be wrong. I have a AVH P3200BT HU. Yuo will be able to put your music on a USB storage device and play it through the USB port but the album artwork will not be displayed.
    On my HU I carry a SD card with music and can listen to that if I want to. I also have a USB port for iP Apple products. Both ports are on thefront panel. Your USB port is in the rear of the HU.
    Good luck but I will say you chose a really nice HU.
  4. Jan 20, 2013 at 4:49 AM
    SNJTacoma11
    if i use a sd card will album art go with songs?
  5. Jan 20, 2013 at 4:51 AM
    ross123
    ross123 Well-Known Member
    fort bragg
    I have the 4400 and I just used bluetooth. Then I got the iphone 5 and all of a sudden doesn't work right any more.
