Pioneer avh 4200 and powered sub
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Puckfreak, May 13, 2022.
  1. May 13, 2022 at 3:39 PM
    Puckfreak
    Puckfreak [OP] Active Member
    2024 TRD Off Road M/T Solar Octane
    Hey there folks. I have what is probably a very stupid question. I have an avh 4200 and I want to add a powered sub. The back panel has sub out l & r. The powered sub has 2 RCA plugs. My question is probably obvious by now. Do I use a split RCA on the l or r RCA, or do I use both l & r sub outs? I have let the smoke out of stereo equipment in my younger days, so I want to be sure...
    Yes, I posted this before, but I guess it was in the wrong forum. Who the hell knows....
  2. May 13, 2022 at 4:04 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Are you intending to drive the sub without an amp? If so, you're going to be disappointed. If with an amp, run both L and R to the amp and make adjustments on the amp to send a mono signal to the amp. Should be dip switch or rotary switch.
  3. May 13, 2022 at 4:13 PM
    Puckfreak
    Isnt the point of a powered sub to not have to have a separate amp? I am looking at something similar to this:
