Pioneer AVH-4300DVD Bypass Question
Discussion in 'Audio & Video' started by SNJTacoma11, Feb 20, 2012.
  1. Feb 20, 2012 at 7:09 PM
    SNJTacoma11
    SNJTacoma11 [OP] Well-Known Member
    Runnemede New Jersey
    2011 Tacoma Double Cab 4x4 Super White
    Rough Country 6" Lift 17" M/T Revolvers 35" Nitto Mud Terrain Cold Air Kit
    I'm trying to install my 4300 DVD w/Bypass and my question is do I need to run a seperate ground for radio or do I just tie in the black ground from the bypass into the radio harness then into the adapter kit?
    Or just into radio harness and run seperate ground into adapter kit?
    Hope I'm explaining this correctly......
    Thanks
  2. Feb 20, 2012 at 7:12 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    Tie it in. A ground is a ground. The relay will have no effect on the way the unit performs when tying the two together because there is still a direct connection from the deck to the ground.
  3. Feb 21, 2012 at 6:34 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    My 4300and bypass are tied into the harness ground. Works fine.
