Pioneer avh-p4300dvd bypass?`s
Discussion in 'Audio & Video' started by 07speedwayblue, Sep 21, 2011.
  1. Sep 21, 2011 at 3:27 PM
    07speedwayblue
    07speedwayblue [OP] Well-Known Member
    michael
    nineveh, Indiana
    07tacoma sport 4x4 doublecab
    Jason Rage lid, husky floorliners, Procomp 6" stage 1 lift , bilstein 5100 upfront, 33x12.50r17 MT ATZ tires MT 17x9 Classic Locks,stainless steel brake lines,N-Fab ss nerf bars,smittybuilt grille saver, Amp bed extender,Mbrp cool dual t409 exhaust. KCHiLites Daylighter Driving Lights 6", Pioneer AVH-P4300DVD, HD Tunner, Rear Camera, Focal K2 Power 6.5" Component Speakers Front/Back, Infinity Kappa Four and Kappa One Amps, Infinity Kappa 10" DVC Subs,PowerStop Drilled/Slotted Rotors ,PowerStop Heavy Duty Towing Brake Pads, Blue Painted calipers.
    If anyone had bypass the brake so you can use the dvd player anytime you want , what did you use or how did you do it. Must new units you can`t just ground the wire that wires into the emergancy brake , so post up if you know? Thanks!!
  2. Sep 21, 2011 at 3:31 PM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    avic411.com
    youtube.com
    both have details
  3. Sep 21, 2011 at 3:32 PM
    beaver_scott
    beaver_scott Well-Known Member
    scott
    renton, wa
    2015 inferno trd pro
    vent shades, tinted windows, clear bra, pop n lock tail gate lock, anytime fog light mod.
    i just grounded the green wire that is supposed to go to the parking brake to a metal ground behind the dash. viola...anytime dvd player.....and my unit is a new jvc in dash nav/dvd player.
  4. Sep 21, 2011 at 4:59 PM
    lbridges
    lbridges Well-Known Member
    Lee
    Indialantic, FL
    '11 PreRunner SR5
    And from a post by rgarjr at the first site mentioned by matt43...
  5. Sep 21, 2011 at 5:06 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    thats kinda basackwards way to wire a relay...
    in the end it would basically ground the parking break wire using the remote wire as a trigger...
  6. Sep 21, 2011 at 5:07 PM
    07speedwayblue
    michael
    nineveh, Indiana
    Thanks!! :headbang: My wife`s truck got broken into about 6 weeks ago and they took the alpine h.u. and ipod. So I just bought a new pioneer avh-p4300 h.u. dash kit iopd controler, wiring harness, hd tunner , reverse camera. i`ll post some pics when I get it done. Thanks guys!!
  7. Sep 21, 2011 at 5:07 PM
    lbridges
    Lee
    Indialantic, FL
    '11 PreRunner SR5
    Won't work on the Pioneer AVH series. The AVH series senses ground state at startup and decides you are trying to spoof the "rules". The easiest/cheap/automated solution is to use the slight delay the remote turn on wire creates a moment after start-up to trigger the relay ground connection.
  8. Sep 21, 2011 at 5:09 PM
    lbridges
    Lee
    Indialantic, FL
    '11 PreRunner SR5
    You have correctly interpreted how the bypass works. The relay grounds, but with a momentary delay induced by the remote trigger wire turn on time.
  9. Sep 21, 2011 at 5:12 PM
    Yoytoda
    Roland
    completely stock
    you could just install a switch that you turn on to ground the parking wire after you turn the radio on. theres your delay lol
  10. Sep 21, 2011 at 5:13 PM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    That is what I did on my HU. Works like a champ.
  11. Oct 2, 2011 at 11:23 PM
    Jabe
    Jabe Active Member
    Gabe
    San Jose... Oxnard
    05 PreRunner SR5
    Blacked Out Badges, Tint, Mag-lite brackets, Ammo Box Mod
    where did you get the reverse cam from ?
  12. Oct 3, 2011 at 4:59 AM
    07speedwayblue
    michael
    nineveh, Indiana
    I bought the pioneer camera, got it off ebay. I think it was 154.00 shipped. I bought a bypass relay off ebay for like 12.00 or close to that. Worked great!
  13. Oct 3, 2011 at 5:33 AM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    just used the power antenna signal wire to activate the relay, it has a short delay after power up so it fools the pioneers.
  14. Oct 3, 2011 at 7:32 AM
    mattg43
    Texas
    08 Prerunner SR5 DC
    You could, and a lot of people do. But a switch and a relay differ in cost by about $1-2 bucks. You dont have to find a place to mount the switch, then toggle it every time you get in your truck. Also, how hard is it to wire a relay if you are already wiring a switch?
    Switch is a hack job. Relay = clean install.
  15. Oct 3, 2011 at 9:05 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    X2
  16. Oct 3, 2011 at 6:20 PM
    Bloodhound
    Bloodhound Space For Rent
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    This is the diagram I used on a 4 post relay (no 87a terminal) and it worked like a champ...I was going to use a switch but after finding the switch for $3.99 and the relay for $4.99 it was kinda WIN WIN for me.
  17. Oct 5, 2011 at 8:40 AM
    07speedwayblue
    michael
    nineveh, Indiana
    I installed the pioneer avh-p4300dvd last weekend. I added the HD tuner and a pioneer rear camera. SWET head unit million time better than the alpine cda-9887 unit I had before. That was the first and last alpine I will ever buy! [​IMG]
  18. Oct 5, 2011 at 11:52 PM
    Jabe
    Jabe Active Member
    Gabe
    San Jose... Oxnard
    05 PreRunner SR5
    thats exactly the head unit i wanted. do you like it ? and also where did you get the backup cam from ?
  19. Oct 5, 2011 at 11:57 PM
    superwhite10
    superwhite10 Well-Known Member
    Garner, NC
  20. Oct 5, 2011 at 11:59 PM
    creedler
    creedler Well-Known Member
    Max
    Eugene, Oregon
    Stock for now
    Old build in sig
    That is exactly what i did. I have the pioneer 3200Bt. However I really never use it. Maybe if I had nav.
