pioneer avh-x5500bhs HELP
Discussion in 'Audio & Video' started by sparks772, Feb 18, 2013.
  1. Feb 18, 2013 at 7:40 PM
    sparks772
    sparks772 [OP] Member
    Ok guys if anyone can help me I'd appreciate it. So started to install my new pioneer but can not seem to find a wiring diagram for this unit and when i google i get OLD results or results that give me colors i do not have. I an using a scosche writing harness but I'm stuck with a hole in my dash and it's 7:30pm, can anyone help a brother out so i can have tunes omw to work tomorrow?
  2. Feb 18, 2013 at 8:38 PM
    loknload
    loknload Active Member
    Woodburn, OR
    OME 886 coils, Alcan AAL, 33" Toyo Open Country M/T
    What wiring diagram are you looking for? the Scosche harness colors should correspond with the wires coming from the 5500. You should be able to match colors...red to red for switched 12 volt, yellow to yellow for constant power, black to black for ground, orange to orange for dimmer, white to white for front left +, white/black to white/black for front left -, grey to grey for front right +, grey/black to grey/black for front right -, green to green for rear left +, green/black to green/black for rear left -, purple to purple for rear right +, and purple/black to purple/black for rear right -. If you have the manual for the 5500, the wiring diagram is on page 46 (section 25). those should be the only wires you need to hook up if you are running everything else stock. If you are running aftermarket amps, then hook up the blue wire from the Pioneer harness to the remote turn on wire to your amps. Hope that helps.
  3. Feb 18, 2013 at 9:14 PM
    sparks772
    Thanks i found it just before you posted, however i think my lack of light was making the colors iffy so i was nervous.
    But i do have a second question. I was told that the face plate would function in our truck with the Metra kit, but i must have done something wrong it don't move with the trim in place.i think maybe it is where i placed my stick mounting brackets on HU? Any help on this new problem would also be appreciated, sorry first time I've done a double din, and been 17 years since i installed my last after market HU.
  4. Feb 18, 2013 at 9:37 PM
    Silverbear
    Silverbear Active Member
    Auburn WA
    06 Tacoma access cab
    AAL 5100 Billys Fog Light mod
    sparks772
    I did the install on a 3500 a few weeks ago. I simply matched up the metra kit with the new stereo to match the old OEM stereo and brackets. Just be careful...there seems to be more wiring with the accessories, and you can risk breaking the adapters if you aren't careful.
    Good luck
  5. Feb 18, 2013 at 10:02 PM
    sparks772
    The stick bracket has holes for four screws, it also has 2 i believe indentations that kind of place the brackets in one alignment using 3 screws. However using that alignment my faceplate does not move and i have a gap between the HU and the top of the trim. But wires and rest were good.
  6. Feb 20, 2013 at 7:50 AM
    2012SilverSport
    2012SilverSport Well-Known Member
    Guam
    2012 Silver TRD Sport Double Cab
    CS Jumpers LED's throughout the cab and marker/DTRL's weather techs/seat covers. Head unit Pioneer AVHX5500BHS, Speakers, Front, Polk Audio DXi 6500 component, rear Polk Audio DXi 650s Subwoofer Sound Ordinance B-8PS, Amplifier Alpine KTP 445U. Front ICON extended travel 2.5 remote resi, Camburg UCA's. Rear ICON 2.0 remote res rear. Wheelers 3 leaf HD progressive AAL,
    Sparks772: Any luck with your install? I have the AVH X5500BHS that is going to be installed soon. I also have the Metra kit that is on the way. did you get the motorized faceplate to work with the kit?
  7. Feb 21, 2013 at 5:46 AM
    sparks772
    Yes i got it to work. 3 things...
    1) as your attaching the stock mounting brackets try to tip the unit up a little, there is a small amount of play with the 3 mounting screws.
    2) as your mounting the stereo press upwards as you tighten the.4 screws down there is a little more play there
    3) when you snap in the dash kit snap it in at the bottom first then the top.
    I'm not sure if it was one of these steps or all 3 combined but when I did those 3 things the faceplate was able to swing out, the first time it didn't.
    Good luck
  8. Feb 21, 2013 at 7:04 AM
    2012SilverSport
    Guam
    That is good news! I am glad it worked out for you, I will use that process once I start my install. I also heard that it can be a bit of a pain getting the kit in the dash all of the way. how does it look now? Any gaps where it is not lining up correctly? Thanks for the assist!!
  9. Feb 22, 2013 at 5:29 AM
    sparks772
    No everything seemed to line up for me fine. Also didn't seem to have any problems getting the wires all in, but i didn't do sat radio or back up camera.
  10. Feb 22, 2013 at 7:09 AM
    2012SilverSport
    Guam
    I am not either. I like my backup camera where it is where i can see the camera and mirror. did you hook up RCA's for an amp?
  11. Feb 23, 2013 at 9:31 AM
    sparks772
  12. Apr 10, 2013 at 10:22 AM
    m0sing808
    m0sing808 Well-Known Member
    do any of you guys deck lowers the volume as it turns on... when i start my car the deck automatically lowers the volume about 5 clicks....is there a why to change this setting???
  13. May 6, 2013 at 12:29 PM
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    11 TRD Off Road - Black
    Icon Stage 5, Nexen Roadian MTX, Fuel KB43 Block wheels, Baja Design XL 80s, Baja Squad Pro WC fogs, TacoVinyl grill, "dudebro" lights, Prinsu rack, trail rash pinstripes, BAMF hybrid bumper, sliders, and LCA skids, and a few other things I can't think of.
    I'd love to see some pictures.. thinking about getting the x5500
