Pioneer AVHP2400BT pre install questions
Discussion in 'Audio & Video' started by everleet, Mar 30, 2012.
  1. Mar 30, 2012 at 3:19 PM
    everleet
    everleet [OP] Well-Known Member
    NY
    07 SR5 TRD Off Road
    I finally decided on the head unit I want for my truck (07 non jbl), that being the AVHP2400BT by Pioneer. It seems to have great reviews and for the price, I think it will be a great fit.
    FYI - http://www.crutchfield.com/p_130P2400BT/Pioneer-AVH-P2400BT.html?tp=20217
    My question is, what pre install issues am I inevitably going to run into?
    Also, what will I need to order seperatly from my crutchfield order? I want the rear camera mod so that for sure I know I will need to order on the side. I keep seeing something about a parking break by-pass, whats the story there? Basically, I want to have everything I'm going to need all at once, I want it to be a one and done operation. Thanks!
  2. Mar 30, 2012 at 5:11 PM
    CascoYota
    CascoYota Well-Known Member
    Casco,ME
    07 Access Cab V6 SR5
    You can either setup your own 12v relay switch for the parking brake bypass, or (which is the road I chose), buy a small pre-made one off Amazon for about $10. Comes with wiring instructions and is incredibly simple.
    As for other parts. Crutchfield supplies the dash kit correct? I ordered from J&R and picked up a metra dash kit separately. Fit great, but had to shave a few plastic tabs down a bit.
  3. Apr 1, 2012 at 9:57 AM
    tacobert
    tacobert Active Member
    Vancouver, BC
    06 DCSB TRD Offroad
    I just installed the same deck with the OEM camera this weekend. It's pretty straight forward. Crutchfield gives you everything you need. If you want to install the parking bypass, you can buy one off ebay/Amazon as CascoYota said, or make one yourself which is really easy.
  4. Apr 1, 2012 at 5:41 PM
    SGar33
    SGar33 New Member
    I just install the same unit on my 2011 acces cab, and i'm loving it!!! it improve the sound by lots with the stock speakers.. I'm now looking to buy the by-pass so that i can watch videos, then maybe put on a sub!!
    also do you guys know if 6x9 speakers will fit on the doors??
  5. Apr 5, 2012 at 8:03 AM
    gpeet
    gpeet Well-Known Member
    just ground the wire for the parking brake
  6. Apr 5, 2012 at 8:07 AM
    gpeet
  7. Apr 8, 2012 at 4:20 PM
    baldridp
    baldridp Member
    Paul
    Las Vegas, NV
  8. Jun 4, 2012 at 3:12 AM
    dza1284
    dza1284 Well-Known Member
    CA
    08 OR Short Bed Dbl Cab
    Bilstein 5100, 2" AAL, Grille, BHLM, Footwell LED, Dash LED, Aero exhaust
    Anyone know what smartphones beside the iPhone are compatible with this unit?
  9. Jun 4, 2012 at 7:56 AM
    CrutchfieldDarren
    CrutchfieldDarren Well-Known Member Vendor
    Darren
    Any modern smartphone should work via Bluetooth. This will let you stream music and handle your phone calls. Only iDevices ( iPods, iPhones) and USB thumb drives will work via USB.
    Hope this helps!
  10. Jun 4, 2012 at 10:54 AM
    the4cecop
    the4cecop Well-Known Member
    Vegas
    2012 Prerunner Sport
    I just installed a AVH-P3400BH and used the relay. Fairly cheap at autozone or O'reillys (6.00). Works well the first time, all you need. Plenty of room behind the HU for it too.
  11. Jun 5, 2012 at 3:28 AM
    tex
    tex Well-Known Member
    Fort Worth, TX
    2006 V8 Sport 4Runner
    Does anyone know if this unit supports any gps apps for the iPhone? Looking at this one or the Pioneer sph-da01.
  12. Nov 7, 2012 at 10:17 AM
    Kenobe
    Kenobe Well-Known Member
    Ken
    Colorado Springs, CO
    09 Tacoma TRD Sport
    Out of the box - no. The only apps it supports are the ones that stream bluetooth audio. Pandora works but doesn't display any screen info. PowerAmp works great and shows track into on the screen.
    There is a GPS module you can get for $400 but I'm not ready to buy that yet. Maybe that will support iPhone and Droid GPS apps? <shrug>
    The Pioneer App Radio supports iPhone/Pad/Pod GPS with an app. Those are $100 or more over the price of this stereo.
  13. Jan 27, 2013 at 12:50 PM
    braggman7
    braggman7 Well-Known Member
    GA
    '23 Trail Edition
    Well, I'm bringing this thread and my TW account back from this grave for this question!
    I ran across this thread while searching and had a similar inquiry so I figured I could just piggyback here. Sorry if this is a violation of etiquette.
    This will be the first HU I'm installing myself, so I just want to make sure I have all my ducks in a row before I get started.
    I have a 2010 DC Sport (non-JBL) and here is what I'm ordering:
    HU:
    http://www.bestbuy.com/site/Pioneer...kuId=4040217&st=pioneer avh-p3400bh&cp=1&lp=1
    (on sale at my local BB for $299)
    Double Din Install Kit:
    http://www.amazon.com/Metra-95-8235...d=1359315892&sr=8-1&keywords=95-8235CHG+Metra
    Wiring Harness:
    http://www.amazon.com/Metra-70-1761...59318933&sr=8-1&keywords=metra+wiring+harness
    Steering Wheel Control Inferface:
    http://www.amazon.com/Metra-ASWC-Un...TF8&qid=1359318963&sr=1-1&keywords=metra+aswc
    Parking Break Bypass (for video in motion):
    http://www.amazon.com/PIONEER-AVH-P...&sr=1-2&keywords=parking+break+bypass+pioneer
    I'm fairly certain that everything above is compatible with my truck and each other. Someone please correct me if I'm wrong. But, I did have a couple other questions:
    I know this HU has a back-up camera option, and my truck as the OEM back up camera. Is there anything special that i need to buy/know before I tackle this? I would like it to operate just like the one I have now (ie. turn on when I put the truck in reverse).
    Do I need anything extra to make it 'XM-ready'? I don't subscribe to it now, but I might in the future.
    Anyone notice anything amiss? Any help would be great!
