Pioneer Avic N1 in 01-04 TACO's?
Discussion in 'Audio & Video' started by jlwilsonjr, Nov 8, 2008.
  1. Nov 8, 2008 at 10:30 AM
    jlwilsonjr
    jlwilsonjr [OP] Well-Known Member
    Has anyone attempted to install this unit? I'm about to give it a shot and was looking for any advice or tips. I'm really unsure where the VSS wire is loacted so any help is greatly appreciated.
  2. Nov 10, 2008 at 3:10 PM
    goin3d
    goin3d Member
    I just finished an install in an 09 xrunner of the pioneer avic 900bt unit. Maybe I can help ya with the wires you're trying to locate? by VSS do you mean the speed sensor?
  3. Nov 10, 2008 at 3:19 PM
    jlwilsonjr
    yes I'm worried about the speed sensor parking brake and reverse wires not sure where they are and where I should splice into them. Any info is greatly appreciated.
  4. Nov 10, 2008 at 3:29 PM
    goin3d
    goin3d Member
    ok..on my 09:
    The speed sensor wire was accessible on the drivers side fuse box. (below and to the left of the steering wheel). The wire was purple with a white stripe. In the fuse panel you should see one plug that is black. The rest are white.
    The parking break wire is green with a yellow stripe. There are actually 2 wires meeting that description in the fuse box and both are in 18 pin plugs. You're looking for the one that is in pin position #5 and should be in the left hand side of the fuse box.
    I hope this helps! (But remember this is based on my 09. I know this layout was the same on the 08's)
  5. Nov 10, 2008 at 6:32 PM
    jlwilsonjr
    Thanks for the info i will keep that in mind.
  6. Nov 10, 2008 at 7:00 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    just fyi, splice the parking brake wire in the harness to the chassis gound in the harness to be able to change addresses and watch video while driving down the road...its a pain to have to pull over and throw it in park to change an address...yeah, thats it...lol
  7. Nov 11, 2008 at 4:42 PM
    jlwilsonjr
    Do i still need to do that if I have had the latest mod done .....board soldiering?
  8. Nov 11, 2008 at 9:27 PM
    The_Hodge
    SC
    ahh...updated discs and the soldering...that i dunno. i'm still running the 40's b/c of the soldering issue. i think you still have to...but if you do it and it doesnt work and says the parking brake wire is grounded, then u can always undo it. do a search on avic411.com and u should be able to get a definate answer though
  9. Dec 8, 2008 at 10:17 AM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    Hi, goin3d
    I have a question, how much is it for the wire harness connect from the new head unit to the exisitng OEM wire harness? and also how much are they??
  10. Dec 8, 2008 at 5:30 PM
    The_Hodge
    SC
    u can get the basic wiring harness from an autozone or advanced auto for around $10. it will not keep the steering wheel controls or the AUX port
  11. Dec 9, 2008 at 5:21 AM
    wing103
    Boston
    Thanks, the basic wire harness is it the one that you hook up from the OEM harness to the new Pioneer stereo wire harness?
    Also the PAC will work on the after market stereo with the steering wheel control, am I right?
    How much will be the PAC that will fit on the 09? can you give me some link ithat I can get it on line?
  12. Dec 9, 2008 at 1:44 PM
    The_Hodge
    SC
    yeah, the $10 harness will go from the pioneer to the stock wiring. the PAC will work for the steering controls. most places are about $40-50. http://www.crutchfield.com has them, but u can check ebay as well
  13. Dec 24, 2008 at 6:33 AM
    jlwilsonjr
    Well finally got around to getting it installed. Install went fairly easy just taking everything out was the hardest part. Just FYI incase you have a bypassed AVIC N1 you have to ground out the parking break wire off the unit even if you've done the latest bypass. Thanks for the info and replies.
