Pioneer DMH-WC6600NEX Information Thread
Discussion in 'Audio & Video' started by ClubSoda, Jun 20, 2020.
  1. May 30, 2024 at 12:44 PM
    #301
    TA-5650
    TA-5650 Well-Known Member
    Wilmington, DE
    2017 TRD OR DCSB, Blazing Blue Pearl
    yes they are. If I recall correctly you need an RCA to 3.5mm for the aux and Maestro makes a cable to adapt to the back of the USB.
  2. May 30, 2024 at 2:04 PM
    #302
    Bubble Wrap
    Bubble Wrap Well-Known Member
    Honolulu, HI
    2016 SR5 DCSB MGM
    You can still use the Germes Lab if you like. I really liked the simplicity of it but didn't know how to make it work with the 6600NEX at first. @svermilyea helped me figure it out and it's been working perfectly just like it did with the OEM HU.
    daveeasa likes this.
  3. May 30, 2024 at 3:25 PM
    #303
    TheCubicleDaydreamer
    TheCubicleDaydreamer Well-Known Member
    19 Cement TRD Offroad
    I had to remove my germes all together to get the headunit/maestro to work. It seemed to have been interrupting the signals from the germes unit.
    Is the power supply from the headunit not sufficient to power the front camera? I can't seem to get it to work.
  4. May 30, 2024 at 6:03 PM
    #304
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Germes works fine just needs power. Germes plug and play harness gets power from a T to the stock NAV unit, no idea why since power is readily available elsewhere. Re-routing power to the Germes off remote out from the pioneer is one option or any ignition switched source is good. On my ‘16 ignition is in the 10 position connector but 2020+ is a new set of connectors for etune 3
    TA-5650 and musicisevil like this.
  5. May 30, 2024 at 9:36 PM
    #305
    Sand_In_My_Taco
    Sand_In_My_Taco Well-Known Member
    NOR*CAL
    2025 1794 Tundra TRD-OR
    Im sure it does, however no need to have it really when the head unit has ability to display two cameras views.
    Just need to get it to detect the second signal :l
  6. May 30, 2024 at 11:50 PM
    #306
    daveeasa
    David
    PNW
    The benefits of mode double click, auto front camera when shifting out of reverse, and hold in either front or rear are super worth it to me. It may not be a need but it’s for sure a very nice thing to have. I wish I had one in my other trucks.
    Nomad26 likes this.
  7. May 30, 2024 at 11:54 PM
    #307
    Sand_In_My_Taco
    NOR*CAL
    Nope. I just activated second cam in HU, then plugged it into the aux cam or second cam plug on the harness.
  8. May 30, 2024 at 11:55 PM
    #308
    Sand_In_My_Taco
    NOR*CAL
    You can have any camera on with this head unit all the time. I had the rear on while my bed was full, just to see the tailgater behind me lol.
  9. May 31, 2024 at 3:38 PM
    #309
    Soooo.... do I need to find a new power source if I want to use the head units front camera connection?
  10. May 31, 2024 at 3:56 PM
    #310
    Sand_In_My_Taco
    NOR*CAL
    I haven't figured it out yet. It's possible I tapped the wrong line, or that it didn't tap properly. I haven't had a chance to look into it yet. However.... It was working before just fine, so I know the camera is good. The HU either isn't picking it up, or there isn't power to it.
  11. May 31, 2024 at 11:37 PM
    #311
    Ahhh interesting. I am getting the little icon to switch to second camera but the screen is still black. My camera was working prior to the swap as well.
  12. May 31, 2024 at 11:38 PM
    #312
    Sand_In_My_Taco
    NOR*CAL
    This is exactly the same thing I have. Button is there, but it's just a black screen.
  13. Jun 1, 2024 at 1:46 PM
    #313
    Sand_In_My_Taco
    NOR*CAL
    Edit: It's working. Checked all my connections and I'm working now.
    Alright... I this head unit just doesn't like aftermarket cameras.
    I swapped the rear view camera output to the second camera input, and it works just fine.
    I verified the camera is working via TV.
    The head unit just doesn't recognize the signal, is my only guess. I also tried to force each signal type in settings, but nothing came through.
    I'm guessing a camera with the right signal type is needed.
    Has anyone gotten the front camera to work with this head unit, w.o ATB or Germes?
  14. Jun 1, 2024 at 2:28 PM
    #314
    TA-5650
    Wilmington, DE
    What camera do you have?
  15. Jun 1, 2024 at 4:06 PM
    #315
    Sand_In_My_Taco
    NOR*CAL
    The Natkia one that was always recommended by everyone.
    Ensure your positive/negative off the camera are hooked up properly.
    I jumped the activator wire to a hot wire so it would activate.
    Camera yellow connector is hooked up to second camera on back of HU.
  16. Jul 10, 2024 at 8:57 AM
    #316
    WyoRoadDog
    WyoRoadDog Well-Known Member
    2018 TRD OR
  17. Jul 10, 2024 at 9:01 AM
    #317
    WyoRoadDog
    2018 TRD OR
    What are you guys using for mapping when you're out of cell service? That was one thing that was good with the old HU, the map was SD card based, and it showed most forest service roads in my area, almost all of which are out of cell range.
    Can Google maps still do that if I download the map for the area?
  18. Jul 10, 2024 at 9:04 AM
    #318
    TA-5650
    Wilmington, DE
    I’m a heavy user of Gaia GPS, because I also hike/backpack and it’s very useful for creating routes. Lots of premium layers including USFS and MVUM etc. there’s a CarPlay app for it. The caveat being that their file organization system is cumbersome and doesn’t work well when you have >1000 waypoints saved. I’ve heard good things about OnX Off-road, but haven’t used it.
    Google should be able to if you download offline.
    WyoRoadDog[QUOTED] likes this.
  19. Jul 11, 2024 at 1:20 PM
    #319
    svermilyea
    svermilyea Well-Known Member
    Scott
    East Tennessee
    2018 Taco Sport (Cement)
    3in leveling lift (Coilovers and AAL) 285/65R18 tires 18" Fuel wheel/tire package Pro Grill, Morimoto XB LED Headlights, DD SS3 Pro Fogs Body Armor Front and Rear Bumpers Pioneer WC6600 head unit w/ OEM Audio + Reference 500 System with dedicated sub amp Meso signal lights, gas hole, led interior lights, ECT relocate, Chrome delete kits Meso Overhead Molle Rack, Seat Risers, Katzkin Leather seats (self installed...it was a fucking bitch) VFTuned .....KDMax Pro!
    Yes, google will allow you to download maps of the area and continue even when you lose service.
    TA-5650 likes this.
  20. Jul 11, 2024 at 8:10 PM
    #320
    WyoRoadDog
    2018 TRD OR
    Thanks. I thought that would be the case, but life hasn’t let me get to the hills to test it yet.
