Pioneer DMH-WC6600NEX Information Thread
Discussion in 'Audio & Video' started by ClubSoda, Jun 20, 2020.
  1. Oct 7, 2020 at 7:15 PM
    #101
    TiHo
    TiHo Well-Known Member
    2018 TRD Sport
    I’d like to know too[/QUOTE]
    Yes with the Maestro you will retain all vehicle settings and steering wheel controls. The only think you lose is the turn by turn directions on the small screen in the instrument cluster.
  2. Nov 2, 2020 at 9:48 PM
    #102
    foolhardy
    foolhardy Member
    2015 Tacoma Sport
    Took the plunge. Here is the initial rough fit of a 6600 in a 2015 using the Metra 5500 kit.
    Took a little more modification than I was expecting and it’s gonna take some finer detail work, but it works and I think it looks great. Doesn’t have the factory look of newer Tacoma’s, but overall I’m happy with it.
    Also added a Scosce wireless charger behind the cup holders, so no more cables.
  3. Nov 2, 2020 at 9:54 PM
    #103
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Looks fantastic to me!
    foolhardy[QUOTED] likes this.
  4. Nov 3, 2020 at 5:03 AM
    #104
    Harsh
    Harsh Well-Known Member
    Norfolk, VA
    2014 White Tacoma TRD Sport
    When you get a chance can you expound on what, where, how you modified to get it installed?
  5. Nov 3, 2020 at 12:25 PM
    #105
    daveeasa
    David
    PNW
    @ClubSoda would you mind augmenting your 1st post with specific details on the GPS vs SAT antenna colors? It's caused some confusion in the past and might be good to have a 1st post with summary info because of that.
    It just came up again in the main thread.
    TIA.
    ClubSoda[OP] likes this.
  6. Nov 3, 2020 at 2:08 PM
    #106
    foolhardy
    foolhardy Member
    2015 Tacoma Sport
    Really not a lot of modification, but had to remove more material than I was expecting. The specs of the two monitors make it seem like there is only 1/4" difference widthwise between the 5500 and 6600 screens. So, I was think I would just need to sand off ~1/8" and be good to go. Not so much. The 5500 kit must be designed to create a frame, recess the screen or something, because I ended up having to remove about 1/4" all the way around. If you look at pics of the kit there is a bend on the sides, I basically had to cut all the way to that. On the top and bottom there are bevels where I assume the 5500 is framed, I had to cut all that away as well.
    I didn't have to make any modification to the mounting brackets. They fit the 6600 perfectly, including the monitor mount. For the dash kit I used a rotary tool with cutting disc and sanding wheel (got a Dremel tool kit at HomeDepot for like $20) to remove most of the material and then hand sanded to clean up the edges. I also took the mounting clips off the factory dash kit because the ones Metra includes are too thin and didn't hold.
    The monitor sticks out slightly at the top and is recessed at the bottom. On the top, it doesn't really matter because only the finished part of the monitor shows. On the bottom and the lower sides, there is a gap, but it's not more than 1/4" and I probably removed a little too much material. It will probably work to my advantage when I fill the gap (current thinking is to cut and glue a thin sheet of plastic to recreate the frame). Then I will sand and paint the whole thing.
    On the stereo install, I ordered from Crutchfield and added their Ready Harness for $25. Everything was pretty much plug and play except for the speaker wires which I had to crimp myself. I even went through the hassle of routing the microphone into the existing overhead console spot. The GPS I mounted under the dash (they recommend to install on top of the dash) and so far it seems accurate. The Maestro app walks you through the setup step-by-step. Pioneer firmware update and CarPlay setup were not the most intuitive process, but eventually got that figured out as well.
    This was my first stereo install and I was surprised it went as smoothly as it did even having to modify the kit. The whole thing took me about 8 hours off and on over the weekend. Probably another couple hours to do the finer finishing work.
    Just for grins I sent the pic to Metra with suggestion they look at making a 2012-2015 6600 kit besides the generic single din floating kit they offer now. Like with 2016+ Tacoma, the 6600 could be a great aftermarket CarPlay/Android unit for 12-15 as well. An off-the-shelf dash kit would help. Doubt anything will come of it, but figured I could at least pass it along.
    wi_taco and ClubSoda[OP] like this.
  7. Nov 4, 2020 at 1:54 PM
    #107
    ClubSoda
    ClubSoda [OP] Well-Known Member
    Harry
    2018 Cement Tacoma TRD Off-Road
    Added under "Installation Tips" :thumbsup:
    daveeasa[QUOTED] likes this.
  8. Nov 13, 2020 at 1:21 PM
    #108
    mikelh
    mikelh Well-Known Member
    Mikel
    Atlanta
    2016 Tacoma / 2010 FJ Trails Team
    What size bezel do you have for this set up? I have an SR with the 6” radio :(
  9. Nov 13, 2020 at 4:31 PM
    #109
    ClubSoda
    Harry
  10. Nov 17, 2020 at 8:33 PM
    #110
    Nived
    Nived Active Member
    San Diego, CA
    19 MGM TRD Sport 4x4 DCSB / 03 White MT Taco
    Just installed mine today, and ive been trying to figure out how to get video to play on the HU from my phone. Can someone give advice on this please
  11. Nov 17, 2020 at 8:54 PM
    #111
    ClubSoda
    Harry
    For videos, since I generally use YouTube, the only way I've successfully watched a video was by using the Browser option on the unit. From the CarAVassist app, you specify links to open, which works, though, it's not intuitive. I'm not entirely sure there's any other way to project a video to the unit, maybe someone on the discussion thread has found a different way. Using the browser has worked for me so far.
    Nived[QUOTED] likes this.
  12. Nov 18, 2020 at 8:36 AM
    #112
    Nived
    Nived Active Member
    San Diego, CA
    Right on, thanks brotha. I tried getting the CarAV to update firmware via my phone but ive seen a lot of people have had issues and found it works best via USB so im gonna try that. Thank again man
    ClubSoda[QUOTED][OP] likes this.
  13. Nov 18, 2020 at 9:22 AM
    #113
    ClubSoda
    Harry
    Yeah the app update can be frustrating. I've found that I have to completely disable Android Auto from launching on my phone, ensure that the HU is connected to my phone's hotspot, and make sure that USB tethering is enabled for the transfer to work correctly. Some folks have it work without any issue. I really wish Pioneer enabled updates within the actual unit itself..
    daveeasa likes this.
  14. Nov 19, 2020 at 8:59 PM
    #114
    SgtRok
    SgtRok Member
    Black Hills, SD
    2020 TRD OR
    TA-5650 and ClubSoda[OP] like this.
  15. Nov 20, 2020 at 10:48 AM
    #115
    Nived
    Nived Active Member
    San Diego, CA
    Hey I'm experiencing a really strange problem with the HU right now and was wondering if you've seen this yourself, or heard from others. Currently my HU is locked on the back-up camera display and I am unable to access anything else. None of the buttons on the side are functional at this time I've tried all the basics to try and reset the unit, but to no avail.
  16. Nov 20, 2020 at 11:10 AM
    #116
    ClubSoda
    Harry
    Not something I've experienced or seen personally. I'd probably try turning the truck off for about 15-30 minutes to see if that helps. I'd contact Pioneer directly though if that doesn't help or if you see this happen frequently.
  17. Nov 20, 2020 at 7:25 PM
    #117
    KingTrevar
    KingTrevar Member
    Trevar
    2019 White Tacoma TRD Off Road
  18. Nov 22, 2020 at 8:08 AM
    #118
    Jamuelsackson08
    Jamuelsackson08 Member
    2017 White Tacoma TRDOR
    Does this headunit work with the factory jbl speakers, amp and sub?
  19. Nov 22, 2020 at 9:16 AM
    #119
    ClubSoda
    Harry
    Crutchfield shows that this radio works with the JBL Setup. I'd reccomended posting this question in the discussion thread, or reaching out to Pioneer for confirmation.
  20. Nov 24, 2020 at 11:32 AM
    #120
    dwillhere1
    dwillhere1 Well-Known Member
    Dan
    Surprise, AZ
    2017 TRD OFFROAD
    I installed a firestick on mine and can watch anything through the firestick. Anything online using the firefox app on the firestick.
