Pioneer doble din won’t turn on
Discussion in 'Audio & Video' started by taco03Trd, Dec 23, 2023.
  1. Dec 23, 2023 at 8:17 PM
    taco03Trd
    taco03Trd [OP] 03 rig trd v6
    Carlos
    Riverside ca
    03 DC prerunner trd v6 2wd
    Ome 881 5100's jba's looking for more
    Hello TW audio folks
    My pioneer
    AVH -290BT won’t turn on I check fuses I’m getting power to unit on back of the unit connector fuse on Estero is also good .
    Any ideas or my unit is done ?
    Was working perfectly and just died yesterday.
    I like that unit very much but also looking to upgrade if anyone selling for a 03 rig
  2. Dec 24, 2023 at 7:08 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    really dumb, but you're pressing the power button, right? some models, if they default to the factory programming, appear to not 'turn on' because the default is 'off' until a button is pressed. had many code brown moments from that stupid functionality.
    Stevie17 likes this.
  3. Dec 24, 2023 at 8:14 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    A few things to check since you have a multimeter
    -yellow 12v in the radio harness, which it sounds like you have
    -maestro is getting power, which it sounds like you have
    -maestro is outputting power to the red accy wire when the truck is on
    you can also grab a paper clip and try the reset button on the radio. Hold it down a few seconds. Normally it’s up by the CD eject button
  4. Dec 24, 2023 at 8:25 AM
    taco03Trd
    Carlos
    Riverside ca
    I try that also with switch on and off and nothing . Ima keep typing today see if she comes back to life if not I guess a new unit would be a late Xmas for me lol .
  5. Dec 24, 2023 at 8:34 AM
    Waasheem
    Waasheem
    2007 xrunner
    Mine, not exactly the same model but a pioneer avh occasionally does the same. Almost always an off and on of the engine will make it turn on. A couple times it didn’t, but then driving down the road a few minutes later it turned on.
