Pioneer Double din installation issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OSOQWK, Jan 6, 2011.
  1. Jan 6, 2011 at 9:46 AM
    OSOQWK
    OSOQWK [OP] Member
    Hawaii
    09 2.7 PreRunner
    K & N Air Charger Pioneer 920B Black Head lights Black Tail lights Color Matched Grille Hids
    I have a pioneer AVIC X920 installed with a metra kit on my 09 tacoma... my questions for all fo you who have a double din reciever is
    1. How do I remove the double din faceplate once its installed without bending/cracking it?
    2. Is it possible to make adjustments to the units placement inside the dash? Id like it to fit a bit more snug and not jut out so much.
    Any help is appreciated, I uploaded pics of the recievers current position.
  2. Jan 6, 2011 at 10:05 AM
    sam_i02
    sam_i02 Well-Known Member
    Samir
    Kanata, Ontario
    05 PreRunner AccessCab
    BHLM, Satoshi grill, D-rings, Relentless Fab recovery shackle, DRL, Firestone RideRite airbags, WO seatcovers, added temp gauge, custom interior lights.
    I have to Schoche (sp?) kit so cant help you with the removal process. Should be straightforward though. The faceplate most likely snaps into a couple plastic tabs. Play with these tabs, to get it off.
    The depth of the unit can easily be adjusted by slightly losening the four screws that hold the brackets onto the head-unit; and then tightening once you have the desired depth. I had to do this about 3 times to get it just how i like it.
    Like the HU. i have a Pioneer AVH-P3100 and love it.
  3. Jan 6, 2011 at 10:23 AM
    steved411
    steved411 I came. I saw. I conquered.
    Clayton, NC
    2008 DC TRD Off-Road
  4. Jan 6, 2011 at 12:19 PM
    OSOQWK
    OSOQWK [OP] Member
    Hawaii
    09 2.7 PreRunner
    Are the steps the same to remove an aftermarket faceplate as it is on the stock radio?
    i didnt do the install myslelf btw, or else this would be simple.
