Pioneer X4600BT Dimmer Ground?
Discussion in 'Audio & Video' started by Max5150, Apr 2, 2014.
  1. Apr 2, 2014 at 3:40 PM
    Max5150
    Max5150 [OP] Well-Known Member
    Mark
    Corpus Christi, Texas
    09 SR5 DC 4x4
    Eibach Springs, Billies set at .85, 2" AAL Audio System: Pioneer AVH-X4600BT, Polk DB 6501, Polk DB 651s, Rockford Fosgate R2SD4-10, Alpine MRP-F320 Amp, Dynamat Sound Dampening
    Installing my Pioneer X4600BT and came across an orange with black stripe dimmer ground wire off the Pioneer Harness. Do I need to connect this to all the other ground connections? I have a ground for the Parking Bypass, and ASWC-1. Any help would be appreciated..
  2. Apr 2, 2014 at 5:05 PM
    Max5150
    Mark
    09 SR5 DC 4x4
    Called Metra, apparently it does not need to be connected..
  3. Apr 2, 2014 at 6:16 PM
    patho
    patho Member
    Mark
    Ontario, Canada
    2005 SR5 TRD Sport Doublecab
    I connected mine.. when your headlights are on (night) it dims the display so it isn't blinding in the dark.
