Pissed off about MPG after new tires
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cutter_, Sep 17, 2020.
  1. Sep 18, 2020 at 7:54 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  2. Sep 18, 2020 at 8:00 AM
    Madjik_Man
    Colorado Front Range
    Let me know if you do. We can drive side-by-side with each other, making awkward gestures, as my OCD is kicked in with mpg and yours with frame rust :)
    Gunshot-6A and tcjacado like this.
  3. Sep 18, 2020 at 8:05 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    OP left :burp:
    Gunshot-6A, tcjacado and BillsSR5 like this.
  4. Sep 18, 2020 at 8:07 AM
    BillsSR5
    bill
    2014 SR5
    he finally figured out he bought a E rated LT tire all terrain that weighs 50 pds. made for the BAJA 500 on his DD Grocery getter
    GQ7227 likes this.
  5. Sep 18, 2020 at 8:10 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I love my E rated tires though
    CrustyTaco, Gunshot-6A and tcjacado like this.
  6. Sep 18, 2020 at 8:11 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    How does "rolling resistance" play into this? I know that my current set of Michelin LTX-2s "feel" more resistant to my butt dyno than the previous two sets of essentially the same tire.
    Maybe OP's new tires don't simply roll as easy as the old set.
    Gunshot-6A and GQ7227 like this.
  7. Sep 18, 2020 at 9:36 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Yes, they do, actually.
    where F = force of gravity, r = distance between center of masses of objects
    and weight = mass * F
    So if you want to loose some weight, go up in altitude.
    I mean, it's a tiny amount given r changes from 41,801,760 feet to 41,807,040 feet (0.01%)
    GQ7227[QUOTED] likes this.
  8. Sep 18, 2020 at 9:43 AM
    jbrandt
    Justin
    It plays a role, sure. The weight plays the biggest role because of inertia. It's hard to get those pigs rolling from a stop, so the motor works harder and sucks more gas. So E rated tires suck the most in city driving/stop and go traffic.
    At consistent highway speeds there's going to be less of an influence from the weight, and more from the rolling resistance.
    Ridgerunner[QUOTED] likes this.
  9. Sep 18, 2020 at 9:46 AM
    jbrandt
    Justin
    Can you reliably measure your gas mileage to 0.01% accuracy (you'd need greater accuracy, actually, like .001%), and control all the other variables that have a much higher impact on efficiency (like air/fuel ratio)?
    If so, then yes.
  10. Sep 18, 2020 at 10:06 AM
    Madjik_Man
    https://youtu.be/4ZfpwfQ58Ds
    frizzman, Gunshot-6A and Rock Lobster like this.
  11. Sep 18, 2020 at 11:43 AM
    jbrandt
    Justin
    Abeyancer likes this.
  12. Sep 22, 2020 at 10:22 AM
    Cutter_
    Cutter_ [OP] I probably could have googled this
    2002 Super Air Nautique Build
    Old Man Emu lift, 2 10" JL subs
    Hey sorry for the late reply. I used to have two stock BFG A/Ts and two aftermarket A/Ts on it from the previous owner, 265/70/16 stock size. The tires were so worn down Pep Boys wouldn't patch them. I had Falken Wildpeak H/Ts put on. They ride better than the worn A/Ts, but I'm getting almost 100 miles less per tank. I called the store and they said they've never heard of that issue with these tires. WTH???
  13. Sep 22, 2020 at 10:30 AM
    Aardvark13
    Aardvark13 Sultan of Squeeze, Wizzard of Slide
    Byl
    Knoxville
    2014 DCSB OR
    Aardvark4x4 Built for Go
    Cutter_[QUOTED][OP] likes this.
  14. Sep 22, 2020 at 10:52 AM
    jbrandt
    Justin
    So what's that in % loss? For me, that'd be like a 40% drop, and there's no way tires alone would cause that high of a drop in mileage.
    I think you need to look into other causes of poor fuel economy.
  15. Sep 22, 2020 at 11:09 AM
    #35
    Cutter_
    Yeah, I don't know what could cause it right after I have them change my tires. Nothing else has changed on the truck. Maybe someone siphoned my gas... lol. I will continue to keep an eye on it and report back after the next tank
  16. Sep 22, 2020 at 11:41 AM
    #36
    jbrandt
    Justin
    Yeah, don't just go by one tank. Once you get a couple tanks in at least. Then maybe start thinking about other things to check.
    Could easily be a coincidence that there are other things wrong, too.
    That said, I typically get about 220 or so per tank for city driving in my 4x4 with 32" E rated A/T's.
  17. Sep 22, 2020 at 12:27 PM
    #37
    Yota X
    Yota X Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
    Bad alignment can do that.
  18. Sep 22, 2020 at 12:29 PM
    #38
    Cutter_
    I had the alignment done, it's spot on. Still room for error?
  19. Sep 22, 2020 at 12:35 PM
    #39
    Yota X
    NW New Jersey
    1st gen
    If it is
    If it is actually good then that doesn’t apply. Did you get the print out that showed the specs?
  20. Sep 22, 2020 at 12:52 PM
    #40
    Cutter_
    Yeah it was off by a few fractions of an inch. It was my first time having an alignment done on a vehicle, so I only understood what the tech explained to me.
