Pissed off at bushwacker !!
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04prerunner, Jul 25, 2010.
  1. Jul 25, 2010 at 6:01 PM
    04prerunner
    04prerunner [OP] Well-Known Member
    kyle
    tampa, Fl
    2004 prerunner
    stock
    So I ordered my Bushwacker fenders about 5 days ago. I ordered them from 4wheelonline.com and they came in really fast, only because these guys are in tampa.
    Anyway, So I ordered the (Extend-A-fender) flares for my (2004 tacoma)
    I did some research and figured this style bushwacker flare would be the closest to the stock fender flare as far as the size
    So I pull them out of the box and everything looks good. I installed the edge trim and drilled the holes in the fenders, then I go to mount them and the fender doesnt even get close to covering up the existing holes from the stock fender, where those orange clips go :confused::confused::confused:
    the front bushwacker fender covered the holes fine, but the rear ones were not even close !!!!!
    the part number on the box was the right one. (31911-11) for my 2004. Im assuming they put the wrong fenders in the box possibly??
    have any of you had this problem with your bushwackers? I called bushwacker and they were not aware of the holes when removing the stock fender??? I just cant believe there hasnt been a complaint about this yet. Im still waiting on 4 wheel online to call me back about returning them
    anyone have any input on this?? here are some pics of the holes so you guys can see what im talkin about. thanks for any help
    if you look at the middle of the fender, It would cover the 3 middle holes, but would not cover the lower holes as you move down the fender. not even close
  2. Jul 25, 2010 at 6:07 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Best of luck getting this corrected. I find it hard to believe that they have been selling this item and no one noticed this. Hopefully just a simple mistake.
  3. Jul 25, 2010 at 6:12 PM
    04prerunner
    kyle
    tampa, Fl
    2004 prerunner
    stock
    thanks dude. the scary thing is I think these are actually the right fenders for the truck. I hope they are not, but everything else seemed to line up fine when I held them against the truck. but this just sucks, and the shitty part is I cant install the stock ones because, 1, I broke all the orange clips,lol, and 2, I tried herculining them and it didnt come out so good. So now Im stuck with no fenders :(:(:(
    but honestly theres something I like about the no fender look :rolleyes:
    the tires stick out a little bit now from the body!! looks kind of good. if there were no holes i might just leave it lol
  4. Jul 25, 2010 at 6:23 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Pics with the flare taped on the truck would be sweet right about now.
  5. Jul 25, 2010 at 6:24 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    oh man that sucks, best of luck to ya getting this rectified
  6. Jul 25, 2010 at 6:24 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    clips can be repurchased...and im sure you can probably sand and reherculine the stock fenders
  7. Jul 25, 2010 at 6:30 PM
    04prerunner
    kyle
    tampa, Fl
    2004 prerunner
    stock
    im at work tonight but i will put the fender to the truck tomarow and post a pic for sure
  8. Jul 25, 2010 at 6:43 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    are you sure you are not trying to put the front ones on the rear?
    I'm not trying to be a dick, we've all done dumbsh*t like that before, just thought I would throw it out there.
    Edit:
    Nevermind, I see looking at the pics the rear would have the notch for the gas door and you already mounted the front...
    so in light of that, I would say yes it is perfectly possible the put the wrong ones in the box
    is there an part number on the inside of the flairs?
  9. Jul 25, 2010 at 6:56 PM
    04prerunner
    kyle
    tampa, Fl
    2004 prerunner
    stock
    thanks man. ya thats the first thing im going to do tonight when I get home is check the inside of the flare and see if theres a part number
  10. Jul 25, 2010 at 9:08 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    man that sucks i hope you get it all figured out. i didnt know the stock flares had holes behind them.
  11. Jul 25, 2010 at 10:25 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    x2 I didn't realize that either. hmmm.
  12. Jul 25, 2010 at 10:34 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    i dont have flares but if you tape the holes from the inside with air duct tape and herculine over it it makes a pretty cool appearance
  13. Jul 26, 2010 at 6:45 AM
    04prerunner
    kyle
    tampa, Fl
    2004 prerunner
    stock
    ? sounds cool. but cant really picture it. Do you know if anyone on the forum has done that?
  14. Jul 26, 2010 at 6:52 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    me minus the tape, you just fold one peice over so its not sticky, and then tape it to the underside where the hole is
  15. Jul 26, 2010 at 6:58 AM
    04prerunner
    kyle
    tampa, Fl
    2004 prerunner
    stock
    and youve seen this before?
  16. Jul 26, 2010 at 7:04 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    what the line-x guy told me i shoulda done, he said the do this to their truck beds whenever they have holes in them,
    haha if you wanna drive up a few (hundred) miles we can reculine my fenders and herculine yours
  17. Jul 26, 2010 at 7:10 AM
    04prerunner
    kyle
    tampa, Fl
    2004 prerunner
    stock
    lol that would be awesome if i could do that. I actually herculined them but didnt do the greatest job so I have to redo them
  18. Jul 26, 2010 at 7:40 AM
    felotacoma
    felotacoma Active Member
    felipe
    miami
    99 PreRunner SR5
    sorry to hear dude and i hope you can resolve this problem.
    hey would you be willing to sell me you your old stock fender flares?? let me know
    thaks
  19. Jul 26, 2010 at 5:07 PM
    Madjik_Man
    Colorado Front Range
    I honestly hate the look of the stock flares. They look so cheesy.
    And I love the look of the no flares look, so long as the truck is lifted and has bigger tires.
    The no flare look with our stock makes it look too "base model" for me. I just the front and rear fenders just flared out of the body itself like the old school trucks did.
  20. Jul 27, 2010 at 5:21 PM
    bajabetty
    bajabetty Member
    Interesting....I thought this was an old thread when I found it today. I bought Bushwacker Extend-a-Fenders for my 2001 Tacoma today and had the same problem - they don't come close to covering the factory holes. I called Bushwacker, no response yet. Luckily the place will take them back and I didn't try installing them yet.
    This is the only mention I can find online about this. Maybe the factory made an error?
