PISSED! SHAKIN WHEN BRAKIN..2002 Tacoma dbl cab rear end shakes while braking?
Discussion in 'New Members' started by jz10toyo, Apr 26, 2013.
  1. Apr 26, 2013 at 11:23 PM
    jz10toyo
    jz10toyo [OP] New Member
    levi
    denver
    sr5 trd
    just bought 2002 dbl cab..144,234mls.. first day off the lot the driver side brake locked up rolling forward at low speed.. took it back, they put cheap rotors, drums and brakes on all around (so they said). took it for a test drive and they had loosened the e-brake all the way.. he tightened it up by pulling it about 200 times..
    ### to get to the point its been less than a month and the rear end shakes like crazy when braking after I drive for 5 min or more.. :mad: had it on the lift at brakes plus and the drivers side tire was hanging down at least two inches lower than the passenger rear????? need help with shake as this is my first Tacoma...:confused::confused:
  2. Apr 26, 2013 at 11:38 PM
    mlittle
    mlittle T O Y O T A
    Michael
    Fort Sill, OK
    2014 Toyota Tundra Crew Max 4x4
    The problem may be the result of the Denver Broncos hitch cover.
    Have the lines been bled? Not sure if one side is grabbing more than the other. What types of adjustments need to be done with drum brakes?
    Nice looking truck. Hopefully, you get this fixed.
  3. Apr 26, 2013 at 11:44 PM
    808DAKINE
    808DAKINE Well-Known Member
    Kai
    Lahaina, Hawai'i
    01 Taco
    Cold air, Sounds, lift, lights, exhaust and a canoe!
    I got one 01 tacoma and it makes small kind vibrations when braking from 55-60
  4. Apr 27, 2013 at 12:10 AM
    Plannerman99
    Plannerman99 Well-Known Member
    So Cal
    Our Adventure Vehicle
    Icon Stage 6ish, Pelfreybilt Sliders, Rancho UCA, Prinsu Rack, Relentless stuff
    It's lifted, right? Could it be driveline vibration?
  5. Apr 27, 2013 at 1:08 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    U have 2 threads about it in the new members section.
    1. No need for double posts
    2. New member area is for introductions
    3. Id either PM a moderator and ask for the threads to be merged and put in the 1ST gen section.
    4................welcome to TW and I ope u get this suspension/brake issue figured out.
