PISSED! SHAKIN WHEN BRAKIN..2002 Tacoma dbl cab rear end shakes while braking?
Discussion in 'New Members' started by jz10toyo, Apr 27, 2013.
Thread Status:
Not open for further replies.
  1. Apr 27, 2013 at 12:17 AM
    jz10toyo [OP] New Member
    Apr 23, 2013
    sr5 trd
    just bought 2002 dbl cab..144,234mls.. first day off the lot the driver side brake locked up rolling forward at low speed.. took it back, they put cheap rotors, drums and brakes on all around (so they said). took it for a test drive and they had loosened the e-brake all the way.. he tightened it up by pulling it about 200 times..
    ### to get to the point its been less than a month and the rear end shakes like crazy when braking after I drive for 5 min or more.. :mad: had it on the lift at brakes plus and the driveers side tire was hanging down at least two inches lower than the passenger rear????? need help with shake as this is my first Tacoma...:confused::confused:
Thread Status:
