Piston misfiring Check Engine Light P0304 P0302 P0300 P0303
Discussion in 'Technical Chat' started by Mike in Orange, Sep 28, 2016.
  1. Sep 28, 2016 at 7:21 PM
    Mike in Orange
    Mike in Orange [OP] Member
    2002 Tacoma 4WD 3.4L V6
    I am having repeated problems with my pistons misfiring. All of the coils, spark plugs, and wiring are less than year old. Compression tests have come back fine. I have put around 6 bottles of fuel injection cleaner into it this year. I have taken my truck to two different mechanics (who cleaned the fuel injectors) and they are unable to fix it. They can only clean things up and tweak it a bit to get it running smoothly. But a couple months later, it comes back. It idles rough and the acceleration is really inconsistent.
    If it isn't the injectors, plugs, coils, or wiring, then what the hell is it?!?!?
    Thanks for your time,
  2. Sep 29, 2016 at 3:16 AM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    02 taco? if so its possible the plug wires are cracked and causing a misfire happened on my buddy truck
  3. Sep 29, 2016 at 6:40 AM
    Mike in Orange
    I don't think it's the plug wires as they were replaced 6 months ago.
  4. Sep 29, 2016 at 6:43 AM
    98tacoma27
    Ben
    Not Beech Creek
    When was the last time the fuel filter was changed? MAF cleaned? Fuel pressure checked?
  5. Sep 29, 2016 at 8:04 AM
    Mike in Orange
    Hey Ben,
    The MAF is not that old and has been cleaned recently. Not sure about the fuel filter/pressure. I'll have to go back through my mechanic receipts and see if it has been replaced recently.
  6. Sep 29, 2016 at 8:10 AM
    98tacoma27
    Ben
    Not Beech Creek
    Did you have the issue prior to the plug/wire change? What plugs did you use?
  7. Sep 29, 2016 at 8:15 AM
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
    Have you had the timing checked?
  8. Sep 29, 2016 at 8:35 AM
    Mike in Orange
    I have had the issue four separate times. In those times, certain plugs and coils were replaced. Can't remember what kind of plugs were put in. Eventually, all the coils and plugs were replaced. The wires were just recently replaced 3 months ago. I believe the timing checked out. The last mechanic that looked at it was stumped because, according to him, he ran every diagnostic check he knew of and everything came back okay. About a year ago, the compression tests came back a little low (150psi), but that has been resolved. The mechanic even got his buddy to come look at it and he had 20 years experience working at a Toyota dealership.
    So as it stands now (according to the feedback I've gotten), I am going to check when/if the fuel filter has been changed out and what type of spark plugs are in there.
    My truck has 253K on it. I was gunning for 300K. Looks like I am not going to make it. Really bummed about that. I was hoping to buy a new car and keep my Tacoma as a beach, camping, mountain truck. My dreams are crumbling!!!!
  9. Sep 29, 2016 at 8:50 AM
    98tacoma27
    Ben
    Not Beech Creek
    If you have anything Bosch (coils, wires, or plugs), change it out with Denso or NGK.
    Are those the only codes you are getting?
  10. Sep 29, 2016 at 8:57 AM
    Mike in Orange
    Thanks. I looked through all my auto garage printouts and those were all the codes that came up throughout the last year.
  11. Sep 29, 2016 at 10:21 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Make sure you are using twin ground plugs, only use NGK or Denso on toyotas (other brands dont work to well in yotas). Also make sure all your vacum lines are not leaking or blown/slipped off. MAF sensor could be a possibility but unlikely, you could do a ohm test on it with the wire coming from the ecu to eliminate any though of that. An ohm test on the plug wires would also verify that they dont have any short in the inside of the wire if you want to check each plug wire individualy
  12. Sep 30, 2016 at 7:40 AM
    98tacoma27
    Ben
    Not Beech Creek
    What exactly do they "tweek" to get it running smoothly?
