Piston slap
Discussion in '4 Cylinder' started by longspur, May 19, 2021.
  1. May 19, 2021 at 3:21 PM
    longspur
    longspur [OP] Well-Known Member
    Tim
    Western Ky.
    2015 extended cab 4x4 4cyl 5 speed
    Have a 15 2.7 5speed 4x4 with 116,000 miles, bought with 99,000 last summer. I have owned several Tacoma’s with the 2.7 and more than 1 had piston slap. This truck started with piston slap last fall when it turned cool and continued all winter. Wasn’t concerned about it since I’ve experienced it before. Problem is since it has warmed up, I’m still getting some. Making me think I’ve got other problems. Thought I would ask y’all if anyone has had the same problems
  2. May 20, 2021 at 7:55 PM
    M37r1c
    M37r1c Well-Known Member
    Rob
    2008 Toyota Tacoma RC 4x4
    How's the oil level? That may be playing a part.
  3. May 20, 2021 at 8:22 PM
    longspur
    Tim
    Western Ky.
    Oil level is fine, and quits when gets up to temp. Been using 0W20, thinking of adding Lucas heavy duty oil stabilizer next oil change and see if that helps
  4. May 21, 2021 at 10:11 AM
    PreRunnerAlabama
    PreRunnerAlabama Well-Known Member
    2015 Black Toyota Tacoma PreRunner I4
    TRD Sport 17" rims Fog Lights OEM Curt Receiver and Hitch
    I thought I was having this "piston slap" turned out it was just an exhaust manifold gasket. They leak on Tacomas and when the truck warms up the gasket seals better when it expands. I see a lot of Tacoma owners thinking they have "piston slap" and its not. Most every case I've seen in person was just the exhaust manifold leak when it was cold making a knocking sound.
    SR-71A and RedWings44 like this.
  5. May 21, 2021 at 11:39 AM
    longspur
    Tim
    Western Ky.
    Worth a look, thanks
  6. May 21, 2021 at 11:41 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Interested to see if the exhaust manifold gasket is really the issue.
    RedWings44 and BassAckwards like this.
  7. May 21, 2021 at 11:43 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I am also interested to hear if that's the cause. I fought an exhaust leak between the header and the midpipe for the longest time until i cut it out and replaced it with a flex pipe and v-band
  8. May 21, 2021 at 12:48 PM
    longspur
    Tim
    Western Ky.
    Won’t be till next weekend because of work. Hopefully this is the cause instead of something more serious. Thanks guys
  9. May 25, 2021 at 8:55 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Please don't use Lucas oil stabilizer. You would be MUCH better off simply using a higher viscosity oil such as 5w30, which is OK to use in your truck even at low temps.
    ecoterragaia and longspur[OP] like this.
  10. Jun 15, 2021 at 6:59 PM
    longspur
    Tim
    Western Ky.
    Little update, just replaced the manifold gasket even though the old one was fine. Still having a little knocking occasionally. And not using Lucas oil stabilizer after some research I’ve done. Kinda scratching my head trying to figure this one out.
  11. Nov 3, 2021 at 4:39 AM
    RBTaco
    RBTaco Well-Known Member
    2013 RC 4X4
    Trac rac, tow hitch, fog lights, tonneau cover, Texas Edition rims, custom console, weathertech floor mats.
    I live in New England and anytime it gets lower than about 45 degrees F, I have that noise. I have had the truck for 7 years and it has done it for 6 of them. It doesn’t seem to affect anything. I let the truck warm up for a few minutes before I drive it and it’s fine. If you do figure it out, please let us know.
  12. Nov 3, 2021 at 11:08 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    piston slap by itself is not an issue
    a cold compression check
    a cold leak down test will tell U everyhing U want to no
    piston slap at normal driving & load can go a long ways
  13. Nov 5, 2021 at 2:07 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    2.7 is infamous for piston slap - I live in NJ - you can install a block heater or a pan heater which will cut piston slap in cold weather to zero minutes of close to it.
  14. Nov 25, 2021 at 11:39 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I haven't made a post on this forum in ages. Just come here to read the new ones every so often. However, I had some very minor piston slap when I first got my Tacoma with the 2.7 about 8 years ago. I switched to 10-30 Amsoil Signature and it went away and has stayed away for 81,000 miles. This morning I wnet out to start it up and it had a knock so bad I thought it would throw a rod. Not a "deep sounding knock" like a crank. More like a rod knock. In any case it went away after about 15 seconds. I went ahead and drove it 400 miles today for Thanksgiving dinner and back. No noise at all after it sat for 8 hours and no problems running it at 75-80 mph the whole way out and back. I'm waiting to see what happens tommorrow morning once it gets really nice and cold again tonight.
    In any case, I thought this was extraordinarily weird. Any opinions or advice would be welcome. My thought is that it's possible the ODV on the oil filter stuck open and that caused it. I am doing extended drains per oil analysis over a period of years and thousands of miles. I don't know for sure off the top of my head but I think I'm at about 7500 miles on the last change which I've done many times before with no problems at all per oil analysis. Maybe a faulty ODV on filter????
  15. Nov 26, 2021 at 5:22 PM
    ROAD DOG
    FEW
    every noise emanating from an engine is very different
    rod knock is louder & not the same as piston slap
    oil change intervals shoudnt effect either at the indicated mileage
    amsoil makes very good oil ..............as good as most
    started after a long no run period
    started on an incline
    started 1 quart or more low
    could yield a knock........................maybe
