PITA lower shock bolt
Discussion in '1st Gen. Tacomas (1995-2004)' started by jdkilroy, Oct 20, 2013.
  1. Oct 21, 2013 at 6:49 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    [QUOTEAbout 3 weeks.[/QUOTE]
    Damnit!!! the dealer has had mine 5 weeks today for the frame and no estimate when they'll be done. Your truck looks brand new, nice job!
  2. Oct 21, 2013 at 7:21 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Neither heat nor cold breaks up rust. Its the expanding or contracting of the metal that breaks the rust. Its not rocket science. If you have a bolt stuck inside something you DONT WANT TO EXPAND IT.
    :deadhorse:
  3. Oct 21, 2013 at 7:22 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Works for me every time
  4. Oct 21, 2013 at 11:06 AM
    jdkilroy
    jdkilroy [OP] Well-Known Member
    Jon
    Southern NH
    '02 4x4 SR5 Access Cab
    You got a free loaner though right ?
    As far as mine looking new...
    In addition to the frame being replaced, in the last 6 months I have replaced or restored: fuel tank, entire rear assembly, both drive shafts and carrier bearing, rear springs and shocks, rear bumper, front bumper (will be replaced with Shrockworks), pulled the bed and did the underside, all the heat shields, rear 1/3 of exhaust system and now currently replacing front shocks and UCA, all 4 CV boots .... the list just seems to go on forever so yeah, shes getting close to brand new. (only has 37 K miles)
  5. Oct 21, 2013 at 7:09 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Yeah I got a Suzuki SUV, they keep saying any day now the parts will be in.. That's a whole lot of work! I got a whole bunch of parts waiting too! An I plan on keeping it undercoated with fluid film. At 37k in that shape that's an amazing truck!
  6. Sep 1, 2020 at 12:51 PM
    CO_T4R
    CO_T4R New Member
    @jdkilroy Old thread, I know. I'm having the exact same issue. How did you end up getting the bolt out?
    Thanks!
  7. Sep 1, 2020 at 1:12 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Make sure all the weight is off the shock .
    A sweet spot mine seem to pop right out
  8. Sep 1, 2020 at 3:05 PM
    Taco302
    Taco302 Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    THIS! First, try compressing the coilover with a crowbar against the LCA. You will likely need a second person to do that and hammer out the bolt. If that doesn't work, you may need to compress the coil with the compressors you can rent at parts stores. Find the sweet spot and hammer it out. Try heating also. It is likely binded.
