Pitfaced BBQ - Meat Massage, Spicy Meat Massage, and On Point - Standing 10% off for TW!
Discussion in 'Non-automotive Group Buys' started by bvbull200, May 31, 2017.
  1. Nov 27, 2017 at 3:09 PM
    #1921
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    As a heads up as some quick feedback... The shaker bottle is one giant clump.:(had to loosen the top bit with a fork to get it to shake some out. Hoping as I use a bit more I'll be able to shake it free but it is full to the brim which is awesome. And tastes amazing still. The pouch feels about the same. Almost more clumped than with out the phosphate it seems. But I usually pinch and apply by hand so no big deal.
    Just wanted to let you know. But I'm still a future repeat repeat repeat customer :thumbsup:
  2. Nov 27, 2017 at 3:12 PM
    #1922
    la0d0g
    running for the hills
    For crawling not hauling
    The eagle has landed!
    Chipskip and Misplaced Nebraskan like this.
  3. Nov 27, 2017 at 3:13 PM
    #1923
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    I think he said he was going to check out brownulated sugar at some point, would make the rub less clumpy.
  4. Nov 27, 2017 at 3:19 PM
    #1924
    Misplaced Nebraskan
    Zach
    Austin
    Still worth it cause I got to lick my fingers more :rofl:
    Chipskip and bvbull200[OP] like this.
  5. Nov 27, 2017 at 3:21 PM
    #1925
    bvbull200
    bvbull200 [OP] Well-Known Member
    Bryan
    DFW, Texas
    2013 DCSB SR5 Prerunner Texas Edition
    Fresh wiper fluid
    I'm going to remain very sensitive to any feedback I get surrounding this aspect. The single big clump is a result of the packaging process (the shaker and pouch is pretty full), but only happens as a result of our decision to stick with brown sugar. I was given samples that used brownulated sugar, but I did not find the taste to be the same and I felt it deviated from the way our rub has been used in the past in that it is a dense, hands on type rub as opposed to a light seasoning, which the brownulated felt like.
    There is a tricalcium phosphate added to help with the clumping and I will say, in using the stuff, this definitely does not clump on its own as much as the original handmade stuff did. You can pack it together and get it to stick, but the handmade stuff would just sort of clump together if you shook it around a bit and could have, at times, little packets of pure brown sugar.
    I feel like the brown sugar version is our rub, whereas the brownulated one was like a similar alternative. Coke vs Pepsi, if you will. I'm very receptive to any further feedback and would be very open to making adjustments down the road if that is what the people want!
    Chipskip and wilcam47 like this.
  6. Nov 27, 2017 at 3:23 PM
    #1926
    horstuff
    horstuff Re-member
    PNW
  7. Nov 27, 2017 at 3:27 PM
    #1927
    horstuff
    horstuff Re-member
    PNW
    Sounds like you need the TW taste testers to do a blind A-B test. Maybe any perceived difference will be a lot less obvious to the masses and worth the switch.
  8. Nov 27, 2017 at 3:40 PM
    #1928
    Misplaced Nebraskan
    Zach
    Austin
    Coke>Pepsi :D
    I say stick with the flavor profile. I like it a lot and also feel the clump is from actually filling the packages with product and not air. I loosened as much as I could and will let it sit for a few days and see what happens.
    As for the bottle and package, very nice! Right sized shaker lid holes. Dispersed what I thought was an appropriate amount. Tested it on some ham and Mac and cheese tonight.
    And once I refill the shaker from the pouch that will cure any clumps. Not turned off by it and didn't want to come off as disappointed. Still a happy camper here.
  9. Nov 27, 2017 at 4:25 PM
    #1929
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    what if you put a slice of bread in the big packages and also looking up a search says use marshmallow to help prevent clumping...while this adds a cost maybe worth it. Just put a small marshmallow at the bottom of a shaker? and a slice of bread in with the bagged stuff? just giving an idea.
    https://lifehacker.com/5463255/keep-brown-sugar-soft-with-marshmallows
    bvbull200[QUOTED][OP] likes this.
  10. Nov 27, 2017 at 4:29 PM
    #1930
    wilcam47
    Will
    Bourbon state
    also an unsalted cracker in the bottom of the container...
    bvbull200[OP] likes this.
  11. Nov 27, 2017 at 4:34 PM
    #1931
    wilcam47
    Will
    Bourbon state
  12. Nov 27, 2017 at 4:43 PM
    #1932
    Drtgrl
    Drtgrl Minus member
    Alana
    Foothills
    2015 MGM Tacoma DCLB
    BAMF sliders with kick up. BAMF all skids. Icons w/ CDC up front. Icon UCA's. All pro expos with 12” kings in rear. Wheelers superbumps. 285 stt pros on black 16" fj wheels. 1" Bora wheel spacers. Relentless tailgate reinforcement. Ditch lights front and rear. Aironboard switches. Aux. bussman box.Center console vault. Esp locking storage. Tuffy bed box. Rear seat molle system. Color matched grill.Rear diff breather mod. ABS switch. PrInSu cab rack. Gusseted spindles.
    I vote for clumps over flavor/ consistency difference. Hands on is never a bad idea when rubbing your meat! :thumbsup:
  13. Nov 27, 2017 at 5:24 PM
    #1933
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    I always take the lid off and wrap the shaker in cling wrap... when I rub my meat. Then I don't have to worry about cleanup or small holes.
  14. Nov 27, 2017 at 6:28 PM
    #1934
    12thmanhawkfan
    12thmanhawkfan Well-Known Member
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
    The goods showed up today! Sadly though it came with a broken lid.
    bvbull200[OP] and Chipskip like this.
  15. Nov 27, 2017 at 6:35 PM
    #1935
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    Glad you got it! Bummed about the lid, though :(. The padded envelope keeps shipping costs down, but if it won't be a viable packaging, then I'll have to keep exploring options.
    Send me your order number, please :).
  16. Nov 27, 2017 at 6:54 PM
    #1936
    Misplaced Nebraskan
    Zach
    Austin
    That's why it needs packaged with a couple foil pouches of rub :cool::D
    Chipskip likes this.
  17. Nov 27, 2017 at 6:54 PM
    #1937
    horstuff
    horstuff Re-member
    PNW
    You oughta recruit 8 go getters from TW (one for each upper and lower time zone) and ship them a good box of all your stuff. Have them canvas local stores to stock your stuff. Payment for canvasers, assuming they’re successful, would be a 5 year free supply of rub (within reason, like a bottle a month). If they’re unsuccessful, a 1 year supply.
  18. Nov 27, 2017 at 6:55 PM
    #1938
    Misplaced Nebraskan
    Zach
    Austin
    Pitface pyramid scheme? :anonymous:
    In:thumbsup:
    scottalot, bvbull200[OP] and Chipskip like this.
  19. Nov 27, 2017 at 6:55 PM
    #1939
    12thmanhawkfan
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
    It's what I get for only buying a shaker of each and not a full bag.
  20. Nov 27, 2017 at 6:56 PM
    #1940
    Misplaced Nebraskan
    Zach
    Austin
    Just gotta use it all on a big smoke now... But @bvbull200 will take care of you for sure I'm betting. Stand up gentleman. :cheers:
    scottalot and bvbull200[OP] like this.
