Pitman arm puller
Discussion in 'Suspension' started by Nostunknivek, Nov 10, 2014.
  1. Nov 10, 2014 at 10:33 AM
    Nostunknivek
    Nostunknivek [OP] Well-Known Member
    Kevin
    Victoria, BC
    '09 TRD OR partially debadged
    Seat belt chime mod, weathertech floor liners, secondary air filter removal,
    I know most of you guys tend to just use a mallet to pound out your balljoints and tie rod ends. I want to get a pitman arm puller. What size should I get? The one I'm looking at from napa is up to 1-5/16". Does that sound right? Will I be able to use it on tie rods and balljoints on my 2009 tacoma?
  2. Nov 10, 2014 at 10:52 AM
    Tanselow
    Tanselow Well-Known Member
    22 trd or
    subd for answer
  3. Nov 10, 2014 at 10:57 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    For Tie-Rod Ends I usually use a Pickle Fork
  4. Nov 10, 2014 at 9:37 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    throw the pickle fork in the trash, get a proper puller.
    i use this snapon one.
  5. Nov 11, 2014 at 7:38 AM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    I used the cheap one from oreilys and it worked just fine. Was like 13 bucks or so if I remember right.
  6. Nov 12, 2014 at 6:44 PM
    15bluetaco
    15bluetaco Well-Known Member
    oklahoma
    15 Tacoma DBSB 4x4
    agreed. i destroyed my tie rod end with satan's pitchfork. i measured my pitman and it's 1 3/4 opening with a 2 1/2 inside at the widest.
  7. Nov 13, 2014 at 5:42 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Can you RENT a tool from a local auto store??
    I've used a combination of things on our Jeep (along with A LOT of PB Blaster).
    For the most part, this worked the best for us. You just have to make sure its the right size (durr). It was cheap...but...I didn't care. Only needed it ONCE.
