PKALL problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by audi2000, May 2, 2009.
  1. May 2, 2009 at 7:33 PM
    audi2000
    audi2000 [OP] Well-Known Member
    Rockwood Maine, Englewood Florida
    TRDoffroad 4x4 6spd
    Installed a PKALL immobilizer bypass, appeared to "learn" the key. But truck will not remote start unless I have key in/near ignition. Starter cranks but doesn't start, will shut off automatically and then try again a few seconds later. Any ideas?
  2. May 2, 2009 at 7:36 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Sounds to me like it didn't recognize the key. Both symptoms are the immobilizer system.
  3. May 2, 2009 at 8:17 PM
    audi2000
    TRDoffroad 4x4 6spd
    It appeared to program correctly, put connector 1 in while holding reset down and then connector 2, flashed 10 beeps really fast. Which is the confirmation of the "learn". Took cables out and put back in, flashes as if bypass was programmed, cannot reprogram so that also indicates a successful "learn"'. Seems to be an issue with the bypass itself, but not sure.
  4. May 4, 2009 at 2:13 PM
    CoreyJ
    CoreyJ Well-Known Member
    Laurel, MS
    TRD Off Road
    PKALL isn't holding the program. Happens alot. Where I work we call them the PK-fail.
