Place to buy 2002 2.7L 4Cyl Engine
Discussion in '1st Gen. Tacomas (1995-2004)' started by DizzyLion, May 3, 2025.
  1. May 3, 2025 at 9:17 AM
    DizzyLion
    DizzyLion [OP] New Member
    Daughter went through some water, got water in the intake and engine seized most likely. Pulled the filter and intake housings, pulled the coils and plugs and attempted to turn it over. Did about a 1/2 rotation and stopped. May try pouring some ATF down the cylinders and let it sit for a bit and try again.
    Debating a rebuild vs. new engine. Does anyone have a reliable/trusted source for an engine that we could drop in?
    Thank you.
  2. May 3, 2025 at 9:29 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    LCE maybe?
  3. May 3, 2025 at 9:54 AM
    02hilux
    Planet: EARTH
  4. May 3, 2025 at 10:16 AM
    Charlie Bravo
    Charlie Bravo Well-Known Member
    Charlie
    Coeur d'Alene, Idaho
    2009 Red Tacoma Access Cab 4wd 2.7MT
    RedLine Tuning hood QuickLIFT, Gen3 alloy 16x7J, All Pro Off-road bed stiffeners & IFS skid plate
    Maybe a source. LC Engineering has been designing, testing, then redesigning and testing with the 2TR-FE engine after Magnuson redesigned the Roots blower. LC Engineering recently announced that they're close to announcing their supercharger assembly for the 2TR-FE engine, so they might be worth calling. Arizona has always been a good place to find used cars (less rust, more retirees).
  5. May 3, 2025 at 10:22 AM
    DizzyLion
  6. May 3, 2025 at 8:20 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
