plain black off road wheels help
Discussion in 'Wheels & Tires' started by tacosupreme54, Aug 2, 2010.
  1. Aug 2, 2010 at 10:03 PM
    tacosupreme54
    tacosupreme54 [OP] Well-Known Member
    NW GA
    Off-Road 4x4 SR-5
    OME 885's, 90000 and n182 shocks, CB drop, 295/75/16 Hankook Dynapro MT RT03's, 16"x8" Pro Comp 7089 wheels, Avid Off Road Light Bar, Magnaflow 12226-14'' Muffler dumped after axle, color matched grille, Team Realtree camo seat and steering wheel covers, Husky floor liners, towing hitch, bed extender, Tacoma bed mat, all black emblems, black sockmonkey decals, bedlined rear bumper.
    i plan on getting some new shoes for the taco when the budget allows. i have had my mind made up on 16" black/flat black wheels for a while. my first options were some helo black maxx 6 wheels, but the price didn't really suit me and they looked a little too "ricey?" (i think that's the word ya'll use on here) idk, they looked too "pretty" or "street" to suit my truck or me. then i looked into the ion 174 black (decent price but too much chrome), some eagle, xd, american racing, and fuel's black wheels but ran into similar issues. they cost too much, too flashy, no 16" wheels to offer and i kinda ran into a brick wall. then i looked more into the plain black steel wheels. i like the simplicity and off road look. they aren't too flashy and i think they will look good on a white taco. i'm going for a white and black look anyway. on top of that, they're cheap! some you can get for like $50-$60 bucks apiece. the thing that's held me back so far is that i have heard about how heavy they are. i've heard that the steel wheel weighs a ton and can effect gas mileage and other things. i would like to ask for any help or suggestions from anybody.
    i just want a black steel wheel. i have heard of aluminum or alloy black wheels from wheelersoffroad.com, but all i can find is the steel ones. if anybody can help me with those that would be great. if not, are the steel ones going to make much/any difference than my stock off road wheels? if there's already a post like this or somewhere else that explains this, i'm sorry. i'm just asking for some help.
  2. Aug 2, 2010 at 10:10 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    i have steel wheels and alloy trd wheels (like yours). i see no diff in mileage. steel wheels IMO are tougher and if your offroading and f a rim you can usually hammer it straight and itll still hold air. crack an alloy rim on the trail and your pretty much f'd
  3. Aug 2, 2010 at 10:33 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    are yours just the stock toyota steel wheels or some that you bought?
  4. Aug 3, 2010 at 7:05 AM
    sfoxwoody
    sfoxwoody Well-Known Member
    Calhoun, Ga
    05 TRD Sport, 4x4, BSP, LB
    none yet
    get the Pro Comp crawlers, they make them in flat black and also have the street locks, they look pretty mean!
  5. Aug 3, 2010 at 7:11 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I'm in the same boat as you. Most of the wheels out there are way too flashy and look like Poo. I have always loved the styling of the these rock crawler steel wheels
    Does anyone know if they make these in the correct backspacing for a Tacoma to clear the calipers?
  6. Aug 3, 2010 at 7:16 AM
    bfogelma
    bfogelma Well-Known Member
    Brandon
    Bend, OR
    2011 DCSB
    look up Cragar Soft 8s
  7. Aug 3, 2010 at 10:47 AM
    Yoytoda
    Roland
    completely stock
    yes. the stock steel wheels are about 28lbs. the wheelers wheels are about 30lbs. the stock TRD OR alloys are 22-23lbs.
    Stock steelies arent quite as heavy as the wheelers wheels but are much heavier than the trd wheels. no diff in mpg from trd or stock steelies
  8. Aug 3, 2010 at 12:29 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
  9. Aug 3, 2010 at 12:31 PM
    Yoytoda
    Roland
    completely stock
    they should... they are 6x5.5 bolt pattern. they are 1" less backspacing than stock so the wheels will stick out 1" further
  10. Aug 3, 2010 at 12:40 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    that's just what i wanted to hear :D
  11. Aug 3, 2010 at 12:41 PM
    rdcar
    rdcar Well-Known Member
    07 tacoma
    I think they have the aluminum and alloy under the 4runner. Don't know why but the steel wheels are under the Tacoma. Check and see if they are also the same size.
    http://www.customcargrills.com/products.asp?cat=67
  12. Aug 3, 2010 at 12:45 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    i didn't think of that, lol. thanks for the common sense man
  13. Aug 3, 2010 at 12:51 PM
    rdcar
    07 tacoma
    Here it is
  14. Aug 3, 2010 at 6:30 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    if you search soft 8s on the older tacoma forums, you will find a lot of threads of folks running into issues with that style wheel...
    since the holes are dimple die, they scrape the caliper... some folks have had success with grinding the vein on the caliper, but a few had gone too far and ended up having to replace their brake systems due to damage...
    on the pro comp soft 8 version, double check the wheel to make sure the holes are laser cut and not dimple die...
  15. Aug 3, 2010 at 6:33 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    in 16x8 for the taco, they come in 4.25" backspace which should be more than enough backspace for a 2nd gen...
  16. Aug 3, 2010 at 7:36 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    thanks man, do you know anything on the pro comp 98's? or any issues?
  17. Aug 3, 2010 at 7:38 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    i havent heard of anyone trying to put the procomp ones on, but there was a TW member recently who ordered the soft 8s from summit racing and they fit...
    worst comes to worst, get them in 5" backspace and if they hit, put a 1/4" wheel spacer and you should be ok...
  18. Aug 3, 2010 at 7:41 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    alright, thanks
  19. Aug 3, 2010 at 7:44 PM
    Yoytoda
    Roland
    completely stock
    have you thought about painting your stock alloys?
  20. Aug 3, 2010 at 7:49 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    yes actually, but i want to run 285's in the future when my duratracs wear out. i know that you can run a 285 with a spacer on these wheels, but i'd rather do it right the first time and get wheels that are originally designed to fit a 285. no offense to anyone with painted stock wheels.
