Plan To Upgrade My Rear Suspension
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MrMolotov, Mar 9, 2025.
  1. Mar 9, 2025 at 9:21 PM
    MrMolotov
    MrMolotov [OP] Well-Known Member
    Ples
    2022 Tacoma SR5 4x4
    None
    So I do a lot of off-roading, and want to upgrade to a 15" rear and want to make sure I have all of the parts I need, cuz I'm a n00b.
    Right now I have a Stage 4 Icon with AAL. I want to keep my extended travel front shocks.
    So I'm planning on some softer Deaver springs, U Bolt Flip, Archive Hammer Hangers, Shackles Cross Tube, extended rear brake lines, shock mount relocation, and 15" rear shocks.
    Since I have Icon fronts, I wanted to keep Icon rears, so I only see them making a 2.0
    ICON Universal 2.0 Aluminum Series Rear Shock, Remote Reservoir, HD Valving, 15” Travel - Icon Vehicle Dynamics
    Is there anything else that I'm missing? Any other upgrades or parts that are required? Suggestions?
    Thanks!
  2. Mar 9, 2025 at 9:26 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    That just about covers it. Ensure your wheels have the proper back spacing as to not rub on the shock bodies during articulation.
  3. Mar 9, 2025 at 10:54 PM
    MrMolotov
    Ples
    2022 Tacoma SR5 4x4
    None
    Im on 33"s with a -12 offset, so I think I'm decent.
    Just need to figure out what Deaver springs I need.
  4. Mar 10, 2025 at 7:58 AM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    16" or 17" wheel? How wide?
  5. Mar 11, 2025 at 9:22 PM
    MrMolotov
    Ples
    2022 Tacoma SR5 4x4
    None
    285/70/17
    Also, I have a 4x4, do I need an Extended Length Axle Shaft?
  6. Mar 11, 2025 at 10:06 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    How wide are the wheels? No need for extended shafts
  7. Mar 12, 2025 at 1:27 AM
    MrMolotov
    Ples
    2022 Tacoma SR5 4x4
    None
    I'm a noob with sizes, you want the rim size? 17x8.5; -12mm Offset
  8. Mar 12, 2025 at 12:16 PM
    jgarverick
    jgarverick Well-Known Member
    2021 DC SR
    You mean driveshaft extension?
  9. Mar 12, 2025 at 12:22 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    You may need 3/4" spacers in the rear
  10. Mar 13, 2025 at 12:08 PM
    Kcruisin
    Kcruisin Well-Known Member
    North Alabama
    '21 TRD OffRoad
    Bumpers and winch
    Pictures? Especially flexing. You're missing the pictures.
    Epic3rdgen likes this.
  11. Mar 13, 2025 at 10:25 PM
    MrMolotov
    Ples
    2022 Tacoma SR5 4x4
    None
    I don't know... do I need anything extended in the rear besides the brake lines?
  12. Mar 13, 2025 at 10:26 PM
    MrMolotov
    Ples
    2022 Tacoma SR5 4x4
    None
    This is all stuff I need to purchase first, I just wanted to make sure I have my whole grocery list ready so I can buy all at once.
  13. Mar 14, 2025 at 7:04 AM
    jgarverick
    2021 DC SR
    No you should be good. I misread. The concern is over the wheel/tire contacting the shock body in the rear yes? If so, you’re really not going to know for sure until you really flex it. Like said above a small spacer may be needed to ensure clearance during articulation. Would recommend bora or spidertrax. I think you can get 3/4, 1, 1.25. Definitely use bolt on hub centric designed for the Tacoma
  14. Mar 14, 2025 at 7:35 AM
    blacktaco77
    blacktaco77 Well-Known Member
    Noah
    21 TRD off road black 4x4
    You may be good w/o running a wheel spacer. Since the shock is a 2.0 and you are running 285’s it might just clear.
  15. Mar 20, 2025 at 2:29 AM
    MrMolotov
    Ples
    2022 Tacoma SR5 4x4
    None
  16. Mar 20, 2025 at 5:45 AM
    Inyo_man
    Inyo_man Don't piss down my back and tell me it's raining.
    U.S.A.
    2023 Tacoma TRD, off-road, access cab
    I'd recommend weighing your rig laden for travel, then compare your needs to the Deaver selection of leaf springs.
    Cheers
  17. Mar 20, 2025 at 6:13 AM
    MrMolotov
    Ples
    2022 Tacoma SR5 4x4
    None
    Might be a dumb question, but can I weigh it somewhere? Truck scale or dump?
  18. Mar 20, 2025 at 11:58 AM
    Inyo_man
    U.S.A.
    Check your area for public scales...
    I've taken rigs to a local packing house that has a scale, others have used the public land fill scales. Simply subtract the curb weight from your total and you'll know the needed spring rate for coils up front and leaf springs in the rear (some folks will weigh the front and back separately).
    This is an important step that many skip. Why guess or estimate the weight of your laden rig, when you can have actual data.
    When getting suspension for my Tacoma, I had it loaded for a trip, then weighed it. I needed Deaver's stage 3 leaf springs and 700lb coils to handle the laden rig.
    The vehicle rides beautifully both on and off pavement.
    Cheers
    MrMolotov[QUOTED][OP] likes this.
