Planning on Long Traveling my toyota for christmas
Discussion in 'Long Travel Suspension' started by elblako91, Dec 5, 2010.
  1. Dec 5, 2010 at 8:33 AM
    elblako91
    elblako91 [OP] Well-Known Member
    Blake
    Lubbock/Houston/Katy
    1992 Toyo Pickup
    Christmas is around the corner and I think I'm going to bite the bullet and long travel my 1992 toyota pickup. I've been researching around and came up with a list of stuff I'm going to buy to make this all work out. I've estimated around $3000 for everything. What all am I leaving out? Things I should look out for? Is this something that I could do in 2-3 days?
    - TOTAL CHAOS GEN II "CADDY" KIT (P.T. 9500)
    - TOTAL CHAOS GEN II SHOCK HOOP KIT (TO MOUNT THE COIL OVERS)
    (P.T. 95602)
    - 2 KING HOSE RESERVOIRS COIL OVER SHOCKS 2.5 X 8" (P.T.PR2508-COHRS)
    - 2 T100 AXLES TO RETAIN 4WD
    If all goes well I hope to have long travel on my rig by new years :stirthepot:
  2. Dec 5, 2010 at 8:42 AM
    06HAOLE
    06HAOLE Well-Known Member
    Sherman Oaks, CA
    2014 Ford Raptor
    Sounds like a cool set-up. Talk to Pat at Total Chaos and see if there are any common wear items that should be replaced when you do the install.
    Take lots of pics and we should go out together and test it out when its done since you down here in Tejas.
    BTW Buy your shocks/kit from Sonny at Downsouth Motorsports. He saved me a ton of $$ when I bought my kit/shocks through him. He gives a great Tacomaworld discount as well.
  3. Dec 5, 2010 at 8:47 AM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Fenders? I think you might need em
  4. Dec 5, 2010 at 8:53 AM
    elblako91
    Blake
    1992 Toyo Pickup
    Yeah I'm gonna need fenders but money tell's me otherwise. I'll get the fenders around the end of January lol. Hopefully I can get buy with out them for a month :eek:
  5. Dec 5, 2010 at 8:57 AM
    elblako91
    Blake
    1992 Toyo Pickup
    Thanks for the advice. I'll be sure to talk to them and compare prices before I buy everything.
  6. Dec 5, 2010 at 9:00 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    whatever else you can afford from this page, buy it. your new suspension is going to bring out all the other weak points (stock) of the truck. i'd upgrade the lower ball joints to the uni balls and get the motor mounts as well. heim steering is nice too
    http://www.chaosfab.com/toyaccess_4wd.html
  7. Dec 5, 2010 at 9:04 AM
    elblako91
    Blake
    1992 Toyo Pickup
    I was looking at that page and found the shock hoop that I needed.
    If I could I would get the lower uniballs and the motor mounts but god thats too much ha. If I just take it easy will I be ok with out that stuff for a while until I can save up more?
  8. Dec 5, 2010 at 9:08 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    you'll be good until something breaks...haha
    yes, if you take it easy then things should be fine but your going to want to push the truck hard cause with the LT you'll be able to. it's fun to go fast
    LT is the gift that keeps on giving, by that i mean you keep spending money on it making it better or fixing it. it's a black hole
  9. Dec 5, 2010 at 9:10 AM
    mntbiker2008
    mntbiker2008 First I derp.. then I herp
    Aaron
    Cincinnati, OH
    93 Pick up 4x4 (sold), 10' Mazda 3
    I am of no help but make sure you post up a build thread of this! I had a 93 so I want to see this build in progress. Good luck!
  10. Dec 5, 2010 at 9:15 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
  11. Dec 5, 2010 at 9:15 AM
    elblako91
    Blake
    1992 Toyo Pickup
    I'll def post a build thread on this. Not sure where it would fit in since i don't have a tacoma but i may just stick it in the long travel section :p I'm trying to decide what i want to do with the rear as I don't want to cut the bed or anything extreme like that.
  12. Dec 5, 2010 at 9:19 AM
    elblako91
    Blake
    1992 Toyo Pickup
  13. Dec 5, 2010 at 9:29 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
  14. Dec 6, 2010 at 8:06 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    Extended brake lines!
  15. Dec 6, 2010 at 8:21 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    good call Chase, but the TC kit already comes w/ new brake lines
  16. Dec 6, 2010 at 8:27 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    double that $3000 and you might have a good start :thumbsup:
  17. Dec 7, 2010 at 5:53 AM
    elblako91
    Blake
    1992 Toyo Pickup
    What could I do for the rear temporarily until I get some more $ to do it properly (L.T.)? I don't want my front end to be up in the air and my back end to be the stock height :p... leaf springs and shackles?
  18. Dec 7, 2010 at 7:10 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    leaf springs and a good pair of shocks. dont do lift shackles
  19. Dec 7, 2010 at 7:40 AM
    elblako91
    Blake
    1992 Toyo Pickup
    Ok no shackles got it. I've been looking around and a lot of people are using deaver leaf springs in the rear.
    I went to deaver's website and found some springs.
    PRODUCT NUMBER: F67
    All Models, 61-1/2", 3" Lift, Long Travel
    $745.36
    This would go nicely as I'll be getting around 3-4 inches in the front. I'm also guessing this is just a bolt on leaf spring and I can use existing hardware? Or do I need to relocate shackles and stuff like that?
  20. Dec 7, 2010 at 7:51 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    those are very nice springs but they require custom fab to mount. they will not fit into stock mounting locations
    i dont think deaver offers a bolt on leaf pack for your truck, however you could have something custom made
