Planning to tow a car dolly with a 4 cyl reg cab
Discussion in 'Towing' started by adamr94, Feb 14, 2017.
  1. Feb 16, 2017 at 12:49 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Maybe contact some transport companies and get quotes to see what they'd charge to deliver it. It may be a better bet at the end of the day. Edit and the life you save may be your own
    tgear.shead and PackCon like this.
  2. Feb 16, 2017 at 12:51 PM
    tgear.shead
    tgear.shead Well-Known Member
    For that matter, and of course, not knowing what kind of shape its in.... if its in decent shape, some temp plates and just drive it on its own 4 wheels.
    ("project" doesn't mean "complete crap", it could mean "stock with high mileage, bad paint, and torn seats")
    Mush Mouse likes this.
  3. Feb 16, 2017 at 12:53 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Fly in and drive that bitch home would be good, too
  4. Feb 16, 2017 at 12:56 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    This guy has no towing experience. Safer rather than sorry. Just because it can be done doesn't mean it should.
    Towing is a learned science.
  5. Feb 16, 2017 at 12:57 PM
    tgear.shead
    Driving with an unfamiliar vehicle isn't going to help make things better.
  6. Feb 16, 2017 at 1:03 PM
    PackCon
    Connor
    Be realistic with someone asking a genuine question. Not sure why you let your ego get hurt by people knocking a 4cyl for long distance towing.
    WOODEX M.E. likes this.
  7. Feb 16, 2017 at 2:12 PM
    1 Bored Clerk
    1 Bored Clerk Well-Known Member
    Vancouver, WA
    '13 4x4 AC TRD OR
    Yes, good catch on the U-Haul. And, Toyota itself recommends (in the manual for the truck, if I remember correctly) not using 5th for towing anything of substance. Shouldn't be going fast enough for the revs to matter much at or near the max tow capacity of the truck anyway. That being said, one can do whatever one wants.
  8. Feb 16, 2017 at 2:25 PM
    Shaun23a11en
    Shaun23a11en Well-Known Member
    Shaun
    So. Cal
    2009 TRD SPORT
    rent the uhaul dolly and get it done. Ive had to tow project cars home many times. the first one i ever did was a 1970 chevy c20 pickup with a bed full of parts and an extra engine. I used the uhaul car hauler and my 2004 silverado 1500 crew cab to yank it home about 200 miles. This was my first time towing. take your time, make sure everything is hooked up and secured correctly and leave plenty of space to brake. You have a truck, use it it
    1 Bored Clerk likes this.
  9. Feb 16, 2017 at 5:47 PM
    adamr94
    adamr94 [OP] Well-Known Member
    Adam
    NC
    06 Regular Cab 4x4
    Well, there won't be any towing going on this weekend anyway. Seller decided to fall off the grid for a few days then said he ended up trading it in the end.
    Guess it wasn't meant to be.
  10. Feb 16, 2017 at 5:51 PM
    Speedytech7
    3435 E Trent Ave, Spokane, WA 99202
    It's less Tacoma and more mod
    Can almost guarantee the dolly is closer to 900lbs
  11. Feb 16, 2017 at 6:00 PM
    evansdmax
    evansdmax Well-Known Member
    Evan
    Western NC
    2017 TRD OR BBP 6 SPEED MT
    If you don't have access to a bigger truck or SUV the go for it.... just be careful and take your time!! I'm only 27 but have towed heavy loads since right out of high school working construction!!! Owning 2 diesels and now my 2.7 I use and abuse it but it always comes out on top!! The main thing with any load is make sure it's secure!!! And loaded properly which won't really mean anything on a dolly
  12. Feb 21, 2017 at 6:52 AM
    tgear.shead
    I happen to be the one being realistic. You are suggesting that not only he deal with a heavy load on the first pull of his life, but that he does so in an unfamiliar vehicle. That is idiotic.
  13. Feb 21, 2017 at 6:54 AM
    tgear.shead
    If they recommend not using 5th, that would be for the AUTOMATIC (V6). Not only that, but the reason they do so is because its easier to say that than to try to explain how to tell if its hunting for gears.
  14. Feb 21, 2017 at 7:20 AM
    PackCon
    Connor
    Not when we are talking 4cyl Taco vs EcoBoost/full size.
    Sounds like you've never towed with anything but a 4cyl. A full size with 3-4k lbs would hardly be able to tell anything was there. That on a mid-size 4cyl and you arent careful, you trash the truck.
  15. Feb 21, 2017 at 7:26 AM
    #35
    tgear.shead
    f150 is a "small" full size. Basically no different than tacoma, just a couple more inches between the wheel wells to fit a full 4' sheet.
    I've pulled more with a 4-cyl than you've pulled with ANYTHING. 3 or 4 thousand is like a bag of feathers.
    And since YOU don't even HAVE a 4-cyl, you are completely out of your element and have no right to make any claims.
  16. Feb 21, 2017 at 9:36 AM
    #36
    1 Bored Clerk
    Vancouver, WA
    '13 4x4 AC TRD OR
    I seem to recall that was for the 5-speed manual in the 1st gen tacomas (v6 or 4) and I believe it's the same manual transmission in the 2nd gen 4cyl. But, whatever...do what feels right for the truck and practice mechanical empathy.
  17. Mar 15, 2017 at 12:29 PM
    #37
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    You can go to www.uhaul.com "Towing & Trailers" You can select tow vehicle & towed vehicle.
    It will tell you if it's recommended or not.
