Plasma Cutter + Air Compressor
Discussion in 'General Automotive' started by Grossomotto, Oct 21, 2019.
  1. Oct 21, 2019 at 6:31 AM
    Grossomotto
    Grossomotto [OP] Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    A question for the metal fabricators out there. I'm buying a Hobart plasma cutter and it requires 3 CFM at 90-120 PSI. My air compressor delivers 6.5cfm at 90psi, will this be enough? Is the 90-120 psi requirement a range or 90 psi is the minimum? Thanks for any info.
  2. Oct 21, 2019 at 6:41 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    You can make an exterior air tank that you can precharge before use. You don't have to rely on the compressor alone while cutting.
  3. Oct 21, 2019 at 6:42 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    The issue for plasma is usually more with CFM than PSI for them to run smoothly. If your compressor is able to keep up with the advertised 6 cfm rating, you should be good. Plasma cutters flow a lot of volume at 90 psi. You’ll want to make sure the tank is big enough to sustain that for as long as you intend to work with the plasma.
  4. Oct 21, 2019 at 6:50 AM
    Grossomotto
    2017 4WDV6LB6MT
    Thanks and to rnish above. It’s a 5 gallon tank so wondering if I need a 10+ gallon external tank? It’s rated at 6.5 CFM at 90 psi, so should be good. Here’s the cutter.
    https://www.hobartwelders.com/equipment/plasma-cutters/airforce-27i-m30071
  5. Oct 22, 2019 at 12:42 PM
    Grossomotto
    2017 4WDV6LB6MT
    Gunshot-6A likes this.
  6. Oct 22, 2019 at 12:45 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
  7. Oct 14, 2020 at 4:43 PM
    Grossomotto
    2017 4WDV6LB6MT
