Plasti Dip MEGA Derp'N Success
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Soft Taco, Jun 2, 2013.
  1. Jun 2, 2013 at 10:50 AM
    Soft Taco
    Soft Taco [OP] For Love of Truck
    Tyler
    Oak Grove, KY
    2013 DCSB 4WD
    Bilstien 5100 set at 1.75", AVS Hood Protector, BFG AT 265/75/16's, Derped Stock Rims,
    Derped my stockerz. 2000 miles later... look brand new. Want chrome back? Peel right off. One full can per wheel. $24. Love that shit. Now... bring on the hate. :D
    Tips, Tricks, & Other Suave'ness
    • Clean rim thoroughly with rubbing alcohol.
    • Spray in a well lit/ventilated area.
    • Wipe nozzle hole clean after each spray session. Spray on paper first to ensure smooth pattern. Chunky is not so hot.
    • I waited an hour between coats. 24 minimum for final cure before remount.
    • One whole can per wheel. I only sprayed what would be seen. Inner areas that never see sunlight remain chrome. BUT... it is smart to "wrap the derp" around the hard angles. Prevents peeling.
    • Let the derp "seep into" the crevice between the tire and rim. Don't let it pool in there, just get it down there and let it seal there.
    • I pried off the emblems after trimming their little feeterz. Then gorilla glued them back on from behind the center cap.
    • Tire left on rim. I used playing cards between tire and rim to prevent overspray.
    • DO NOT LET THE DERP DRY TO THE CARDS. Otherwise you will peel some of your good derp off when lifting away the cards. Cards. Spray. Remove cards. Dry. Repeat.
    • After each spray session I put a fan directly on it to promote drying and also leaves a smooth final finish. No bumpy derp. Watch out for debris the fan may stick to your fresh derp. i.e. dust, wood chips, small shit in general.
    • Took entire weekend ONLY because I am a perfectionist when it comes to my truck, I am lazy, and my wife demanded we watch Lord of the Rings extended editions back to back to back to ba....... good woman.
    My "Pro Card" TAPE OFF Argument (A few TWers say dont worry about taping or carding off rim.)
    Rim is on the ground facing heaven. Cards in place. Spray. Remove cards. Let dry. The derp has created a natural thick bead of itself in that crevice now. It dries to a more durable, less prone to peeling, thicker ring of derp. Not doing this will require slicing the excess derp from the tire to rim overspray. A blade will only leave the thin coat of derp freshly sliced and exposed. Derp is like a surgical glove. Whats at the base around the wrist? A thick rib. Without that rib the glove will tear or slip like no ones buisness. For you "don't worry about taping/carding" guys and gals... one day you will be pressure washing all innocent like, and then..... DERP PANCAKE WATER BALLOON FUBAR! :eek: My .02
    _________________________________________
    Great tip from flatblack
    "don't know if anyone's experienced this; but, (despite wiping nozzle and spraying upside for 5 seconds, as recommended) while waiting between coats, my nozzle would always get slightly plugged up; and the following spray would be all chunky and ruin everything i had done up until that point i bought some mineral spirits and dumped some of that business into the cap and placed the the spay can into it upside-down (submerging the nozzle in the the spirits), between coats didn't have any more clogging problems afterwards"
    __________________________________________
    Great tip from pikachu
    "The sig pic of my car below is a plasti derp white base coat and the gold is actually spray paint. Totally reversible and dirt cheap!"
    ___________________________________________
    NOW GET DERP'N:cool: And good rep is always appreciated ;)
  2. Jun 2, 2013 at 10:55 AM
    somethinboutayota
    somethinboutayota Dorthy left Kansas for a reason
    Parker
    Dodge City, Kansas
    Go to get alignment- replace whole front end
    Debadged and painted, plasti-dip bumper , Sock monkey decals, tool box, K&N cold air intake, flag holder/fishing pole holder, Satoshi, magnaflow 40 series, spidertrax wheel spacers, map lights, led reverse lights, led dash assembly lights, roof top LED bar
    :thumbsup: nice! Cant believe they have held up that long great job!
  3. Jun 2, 2013 at 10:55 AM
    Cmurder
    Cmurder 2011 TX TRD Offroad
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
    Hate?! they look good and you can make them look original at any time. i say good work.
  4. Jun 2, 2013 at 10:59 AM
    Soft Taco
    Tyler
    Oak Grove, KY
    2013 DCSB 4WD
    I pressure wash the fudge out of them. Trick is to make sure there are no corners or lips that can be peeled back.
  5. Jun 2, 2013 at 11:16 AM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD OffRoad Poser ψ(`∇´)ψ
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Hell yea! I will prolly do this too!
  6. Jun 2, 2013 at 11:32 AM
    SWCCBEE
    SWCCBEE So Cal Edition
    Greg
    Santa Rita, GU
    2010 PreRunner, SR5, TRD Sport
    WeatherTech floor liners, In process of Debadge, Leveling kit, Tires, Limo tint, Custom TRD SPORT Decal, "ImMrYo" Rear view lifting bar, Ultra gauge, relocated horn.
    So just spray on?
  7. Jun 2, 2013 at 11:33 AM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    Clean well first, but yep, just spray it on in multiple coats. No sanding required
  8. Jun 2, 2013 at 11:40 AM
    SWCCBEE
    Greg
    Santa Rita, GU
    I have been asking around to powdercoat my stocks.....$100 a wheel. This sounds way better!
    Tire left on or have to take off?
  9. Jun 2, 2013 at 11:43 AM
    Soft Taco
    Tyler
    Oak Grove, KY
    2013 DCSB 4WD
    Bingo.
    • I waited an hour between coats. 24 for final cure before remount.
    • I pried off the emblems then gorilla glued them back on from behind the cap.
  10. Jun 2, 2013 at 11:46 AM
    Soft Taco
    Tyler
    Oak Grove, KY
    2013 DCSB 4WD
    Tire left on. I used playing cards between tire and rim to prevent overspray.
    Otherwise you will peel some of your off your good derp when lifting away the cards. Cards. Spray. Remove cards. Dry. Repeat.
  11. Jun 2, 2013 at 11:52 AM
    majorhavok
    majorhavok Rabid Conservative
    Mike in Cali..
    Peoples Republic of Caulifournia
    '13 TRD Sport DoubleCab 4x4
    Ultragauge, ImMrYo mirror, Tailgate lock, Snugtop Rebel Shell.
  12. Jun 2, 2013 at 11:56 AM
    SWCCBEE
    Greg
    Santa Rita, GU
    Yeah I want to do the Wheels and TACO badges on doors.
    Thanks for info!
  13. Jun 2, 2013 at 11:59 AM
    Soft Taco
    Tyler
    Oak Grove, KY
    2013 DCSB 4WD
    :thumbsup:
  14. Jun 2, 2013 at 12:04 PM
    VinnyMack
    VinnyMack Well-Known Member
    Casey
    Buda, Tx
    07' PreRunner DC LB
    Brute Force Hybrid w/ custom Longhorn cutout, Satoshi w/ Hella 500's, Wet Okole's, Kenwood DDX419 CD/DVD Player, Fog Lamp Mod, BHLM, Blacked-out badges/grill/roof/valence, 5100's up front @ 1.75, 1.25" Spidertrax, TacomaWorld Sticker, extra D-Rings and custom bed mat, interior LED lighting, and Car Seat Mod.
    Great job!
    I have same wheel and tire setup and did mine on truck and didn't tape off wheel. Just peel over the tire and comes off easy in a ring of rubber. I just stuffed plastic bags in void areas so the brakes/rotors didn't get any overspray. Just make sure the derp is try before you pull the bags off.
  15. Jun 2, 2013 at 12:07 PM
    Soft Taco
    Tyler
    Oak Grove, KY
    2013 DCSB 4WD
    Off truck is highly reccomended. You can "wrap the edges" from behind like I had listed. Prevents peeling and promotes health, longevity, and good fortune. But your way works for those short on time and lacking a jack!
  16. Jun 2, 2013 at 4:08 PM
    AeRoRabbit
    AeRoRabbit AeRoRabbit
    Memphis, TN
    09 Dbl Cab SR5 TRD Off Road 4X4
    Wonder how it will hold up with taking the wheel weight off and on?
  17. Jun 2, 2013 at 4:15 PM
    Agent Smith
    Easy to touch up, but I had my wheels off already in prep for new tires, and had the tape weights on the back of the rim installed.
  18. Jun 2, 2013 at 4:21 PM
    AeRoRabbit
    Memphis, TN
    And where do you buy this stuff from and what is it called?
  19. Jun 2, 2013 at 4:26 PM
    Agent Smith
    Plasti Dip and you can get a spray can at Home Depot in the spray paint aisle. Do a search on here, mega thread about it.
  20. Jun 2, 2013 at 4:27 PM
    SWCCBEE
    Greg
    Santa Rita, GU
