Plasti dip or emblem overlays?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Natenite, Feb 10, 2020.
  1. Feb 10, 2020 at 1:35 PM
    Natenite
    Natenite [OP] Well-Known Member
    Springfield Mo
    2003 Tacoma 4d TRD Radiant Red
    Looking to get rid of the chrome as much as possible. Anyone have any suggestions on if it’s better to plasti dip the existing ones that are already on there or if the overlays do better? Do they even make overlays for the first gens? Thanks for your thoughts!
  2. Feb 10, 2020 at 1:40 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    I didn’t do either...
    I just got black emblems, removed the chrome ones, and the black ones in there place. Sixty bucks for a complete set on Amazon!
    seanb06 and Natenite[OP] like this.
  3. Feb 10, 2020 at 1:52 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Yes they do. There's another thread that's recent that talks about them. First google result is an Amazon link. $130+ for the overlays.
    Seems a bit steep for something that $0.45 worth of plastidip will do. Plastidip isn't all that durable, so I'd take your chrome ones off, scuff them up with a scotchbrite pad or fine sandpaper and throw a few coats of paint on them. and reinstall using double stick tape.
  4. Feb 10, 2020 at 1:54 PM
    PennSilverTaco
    Charlie
    I tried the PlastiDip thing and it didn’t work out too well; How are you supposed put the emblems back on properly?
  5. Feb 10, 2020 at 1:56 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Imo, plastidip used in any situation looks cheap and half assed. They dont call it automotive AIDS for nothing. Find some black emblems and do it right the first time like was mentioned above.
    PennSilverTaco likes this.
  6. Feb 10, 2020 at 1:56 PM
    PennSilverTaco
    Charlie
    :amen:
  7. Feb 10, 2020 at 2:04 PM
    tacomainthesun
    tacomainthesun Well-Known Member
    02(sold) 17 trd or
    Bed liner spray holds up and is deep black color
  8. Feb 10, 2020 at 2:13 PM
    Natenite
    Springfield Mo
    Thanks for the thoughts everyone! I thought I saw plasti dip being applied while the emblems were still on the vehicle. I like the idea of just getting new black ones so I’ll start there. Is it hard to remove the current ones? Any tricks to that?
  9. Feb 10, 2020 at 2:14 PM
    jbrandt
    Justin
    Not that I've done this before, but I did stay at a Holiday Inn once...
    I would put some masking tape around the emblems. This will not only presever the location of them, but keep your paint from getting scratched as you are pealing them off.
    For re-attaching them, not sure, but I've seen some liquid adhesive stuff that people seem to like.
    https://www.autozone.com/sealants-g...m-plastic-emblem-trim-adhesive-1oz/316901_0_0
    Or molding tape?
    https://www.amazon.com/3M-3614-15/dp/B002JOVUO0
  10. Feb 10, 2020 at 2:15 PM
    jbrandt
    Justin
    Patience, lol...
    https://www.wikihow.com/Remove-Emblems-From-Cars
    For doing the plastidip ON the vehicle, you just mask off the area and paint of it, then you can trim around the edges of the emblem and peel off the excess.
  11. Feb 10, 2020 at 2:16 PM
    Natenite
    Springfield Mo
    I’m not finding first gen black emblems. I see ones for 2016 and on. Possibly some for 2nd gen too. The only first gen stuff is chrome. Might have to just paint these huh?
  12. Feb 10, 2020 at 2:16 PM
    tacomainthesun
    02(sold) 17 trd or
    Yes. I’ve done the bedliner on my door sill protectors on my first gen and it doesn’t get messed up despite entering with boots
  13. Feb 10, 2020 at 2:18 PM
    tacomainthesun
    02(sold) 17 trd or
    Yup. Cheaper too. Plastidip will flake off in a way over time and wear so I wouldn’t recommend it unless you only wanted temporary
  14. Feb 10, 2020 at 2:19 PM
    jbrandt
    Justin
    Bed liner probably isn't the best to use if you plan to leave the emblems on. Plastidip you can peel off. Can't peel off bedliner.
  15. Feb 10, 2020 at 2:21 PM
    seanb06
    seanb06 Well-Known Member
    Sean
    AZ
    06 PreRunner TRD OR
  16. Feb 10, 2020 at 2:22 PM
    jbrandt
    Justin
    Not OEM ones, no. They're out there (as are the overlays), but they're pretty damn expensive. Since you'd have to peel off the chrome ones anyway, might as well just paint them.
  17. Feb 10, 2020 at 2:24 PM
    jbrandt
    Justin
    I would hope not. Bed liner is supposed to be super durable.
    But we're talking about painting the chrome badges/emblems.
  18. Feb 10, 2020 at 2:26 PM
    tacomainthesun
    02(sold) 17 trd or
    Yes. That’s the only application I’ve used the liner for, just an example of how it proved to be very durable.
  19. Feb 10, 2020 at 2:27 PM
    tacomainthesun
    02(sold) 17 trd or
    I thought plasidip was good until I tried it and it wore out way faster than I expected
  20. Feb 10, 2020 at 2:33 PM
    jbrandt
    Justin
    Yeah, that stuff isn't all that durable. It's just relatively easy to apply. One of the main benefits of it is that it is easy to remove, too (by definition not very durable, lol).
    I plastidipped my fender flairs, and it's worked ok, but if (when) I do it again, I'll just do bedliner.
    In retrospect, I should have just done bedliner in the first place. I ended up taking my flairs off and sanding them down anyway (clear coat on them was coming off). But I already had the spray cans of plastidip.
