Plasti-Dip vs Bed Liner Sleep System
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cpmanley, Feb 10, 2020.
  1. Feb 10, 2020 at 6:16 PM
    cpmanley
    cpmanley [OP] New Member
    Cass
    Portland, OR
    2011 Taco 4x4
    So I have done a bunch of digging around and feel good about the sleep system I plan on building in the back of my truck, thing is I won't use it only for sleeping. I often haul dirty dogs back there too (wet/muddy etc). SO my question is has anyone ever used plasti-dip or bed liner to coat the wood in their set ups? How does it hold up to wear and tear? If this question has already been asked or I'm overlooking the obvious answer please let me know. I'm going for affordable and durable. Don't care much for looks. Thanks.
  2. Feb 10, 2020 at 6:29 PM
    cjsqueeky
    cjsqueeky Well-Known Member
    chris
    Chesapeake VA
    15 tacoma dbl cab
    front 2.5 headstrong lift, Freedom offroad UCA, 3 inch rear custom helwig lift, custom double cardon 2 piece drive shaft
    I wouldn't use Plastidip.. I have been looking a monstaliner for a project. Maybe it will work for you.
  3. Feb 10, 2020 at 6:44 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Plastidip will not hold up on a part that is used. Its great as peelable paint but not for dog claws, shoe traffic etc.
    pdaddy likes this.
  4. Feb 10, 2020 at 6:47 PM
    cpmanley
    Cass
    Portland, OR
    2011 Taco 4x4
    Awesome, thanks for the beta. Looks like I'll be going bed liner.
  5. Feb 10, 2020 at 6:51 PM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    I agree, plasti dip is literally advertised as “peel-able” paint
  6. Feb 10, 2020 at 6:53 PM
    cpmanley
    Cass
    Portland, OR
    2011 Taco 4x4
    I know it peels off of non-porous surfaces, but I had heard that it stuck pretty well to wood. My thought was since it was rubberized it would expand/contract with the wood while still providing protection from wetness and mud. Also it's a bit cheaper.
  7. Feb 10, 2020 at 6:56 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    When I painted my platform used a kilz primer and an oil based Rust-Oleum paint. Stuff was durable as hell but did end up loosing its gloss finish when stuff rubbed/ vibrated on it for long trips.
    I have since covered my platform in automotive carpet I picked up at Home Depot. I prefer this over the paint as it is easier to slide stuff over it and when I crawl in there it is much softer on my knees
    cpmanley[OP] likes this.
  8. Feb 11, 2020 at 6:45 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    For ease of cleaning, I would go with covering it with black vinyl. The same material used on weight benches and likely be found at any fabric store. You can easily install it with a staple gun and still be cheaper than rattlecanning bedliner.
  9. Feb 11, 2020 at 7:19 AM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Vinyl isn't going to hold up to dog claws or sliding anything irregularly shaped over it. Bed liner would be my first choice followed by some sort of rubber mat.
  10. Feb 11, 2020 at 7:28 AM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    Good point. My next suggestion would be the easiest route which would be simply placing a factory rubber bed mat over the platform.
