plasti dip
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bobbybreach, Jan 27, 2013.
  1. Jan 27, 2013 at 5:29 PM
    bobbybreach
    bobbybreach [OP] Well-Known Member
    bobby
    westchester NY
    09 TRD
    hey guys i was looking to plasti dip my grill and part of the front end and i was curious if i should give it a good sanding before i spray it with plasti dip or if i should just clean the area and just spray. what should i do for best application?
  2. Jan 27, 2013 at 5:30 PM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    No sanding. Get it clean and free of waxes and road grime. That way if you don't like it you can peel it off and the oe finish will still look good.
  3. Jan 27, 2013 at 5:35 PM
    tex
    tex Well-Known Member
    Fort Worth, TX
    2006 V8 Sport 4Runner
    If you want it to look good use this
  4. Jan 27, 2013 at 5:40 PM
    ntilehman
    Seth
    Charlotte, NC
    Then you will need to do a proper prep job on whatever you are painting. Use a good primer as well.
  5. Jan 27, 2013 at 5:57 PM
    bobbybreach
    bobby
    westchester NY
    09 TRD
    ok cool. any idea what most people do? i figure i will plasti dip it first and see how i like it. if i do like it a lot then i can spray it. but as far as plasti dip, do you just spray it on like how you would with spray paint?
  6. Jan 27, 2013 at 6:25 PM
    ntilehman
    Seth
    Charlotte, NC
    Yea just use light coats and build up slowly. See what it looks like with the plasti dip first. It holds up well in most cases. People have wheels done that last for years. Obviously a proper paint job with a hardened clear will last much longer.
  7. Jan 27, 2013 at 6:36 PM
    seric007
    seric007 Well-Known Member
    one thing, with it being cold and all, don't spray plasti dip less then 70 (warmer if possible)... it will spray VERY clumpy and "Trap" solvent leaving behind a nice bubbley finish.
    do it in warm area and plasti dip is goooood stuff. :thumbsup:
  8. Jan 27, 2013 at 6:42 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    I did my lower valance on my truck 1.5 years ago. Tons of light coats with the first 3-4 being just to lay a splatter base coat. It was a warm 75deg day and I waited 20-30 between coats.
    Overall on just the lower valance I used 3/4 can.
    It still looks as good as the day I did it. Pics in my profile.
  9. Jan 28, 2013 at 8:53 AM
    dritchey10
    dritchey10 Active Member
    Daniel
    Maryville, TN
    2010 Dbl Cab Taco V6 Auto 4WD
    2" lift
    Hey man I just did my grill yesterday. It's super easy.
    Here's a tip if you're doing it in cold weather like I did since it was unavoidable and I didn't have a garage big enough to do it in. Take the cans of Dip into your house or garage and place them next to a heater vent (not on the heater or vent, just near it) to get them room temp or a little warmer then go outside and spray your next coat on then take them back in and place them at the vent again. That way it doesn't get lumpy.
    It does a great job though and if you tape off anything be sure to be careful when you peel the tape off as the dip wants to pull off with it! Pull away from the dip, not towards it.
    Hope that helps. I did my wheels too and the stuff is holding well. Just have to pay attention and do a good job.
  10. Jan 28, 2013 at 1:44 PM
    bobbybreach
    bobby
    westchester NY
    09 TRD
    Your taco looks great! Thanks do all the advise guys! I wish it was 70+ to spray properly but I'm gonna take your advise and just get the cans to room temp for every coat. I will probably set up my portable heater facing the front end so at least there will be heat applied after each application.
  11. Jan 28, 2013 at 3:10 PM
    tensecondchevelle
    tensecondchevelle Well-Known Member
    Eric
    Mesa Arizona
    2006 Tacoma Double Cab
