Plastic bedliner 'slots'
Discussion in '2nd Gen. Tacomas (2005-2015)' started by petersharp, Jan 11, 2008.
  1. Jan 11, 2008 at 4:30 PM
    petersharp
    petersharp [OP] Well-Known Member
    Do you need to ask?! It's up there ^
    Louisville, CO
    Ex DC LB Sport owner.
    My 2007 longbed Prerunner has 4 'slots' in the ridge that runs the length of the bed walls (see attached pics, the slot is above the inverter). I was thinking of making up 2 planks (either wood or aluminum) that would sit in these slots to go across the width of the bed for carrying 8' x 4' sheets of drywall/lumber etc. The width between the wheelarches is less than 4' so an 8' x 4' wouldn't sit on the bed floor properly.
    I wanted to make the top surface of the planks the same height as the ridge and wheelarches for maximum support of the material; if I use a standard 2" x 6" it will be too high :( unless is sand it down a bit.
    Has anyone done this? If so, what material did you use? And how much load did you put on there?
  2. Jan 11, 2008 at 5:15 PM
    marvin02
    marvin02 Well-Known Member
    '07 Access Cab SR5 - Black
    Top Dawg Folding Tonneau Cover, DIY Bed Light, Aux. Input for MP3 Player, OEM Bed Mat
    Most people just use standard lumber because anything you put in that is 4 feet wide won't rest on the ledge on the side of the bed anyway.
  3. Jan 11, 2008 at 5:22 PM
    petersharp
    Louisville, CO
    Thanks for your reply. I thought that it might be good to use the wheelarches as support as well.
  4. Jan 11, 2008 at 8:10 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    I dont know the lenght of that particular area but would a 1x6 or 1x8 #2 pine work?
  5. Jan 12, 2008 at 6:47 AM
    petersharp
    Louisville, CO
    I can't say that I have tried those exact boards but when I visitted my local Home Depot I couldn't find anything of standard thickness that would go straight in without modification.
    I was also planning to an extra support for the 4' x 8' sheet on the lowered tailgate but reading the thread about how weak the tailgates are makes me a bit nervous about doing that.
  6. Jan 12, 2008 at 10:52 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    If your tailgate brace covers the whole tailgate to spread the weight evenly you should be fine. The tailgate can support a lot if weight IF it's evenly distributed. The problem comes when a lot of weight is only support by a small area like the center, or 2 wheels of an ATV on the edge.
  7. Jan 12, 2008 at 10:54 AM
    piercedtiger
    Jon
    Southern Tier, NY
    Or, if you have a hitch, you could get a brace that slides into the hitch so none of the wood, drywall, etc sits on the tailgate.
  8. Jan 12, 2008 at 11:33 AM
    piercedtiger
    Jon
    Southern Tier, NY
    ^Thanks. I can never remember what they're called... :laugh:
  9. Jan 12, 2008 at 12:05 PM
    surfsupl
    Gregg
    WestCoast
    Very nice!...If I could get away with it I would drive around with that on all the time! (damn So Cal drivers!)...Where did you find that?
  10. Jan 12, 2008 at 1:31 PM
    surfsupl
    Gregg
    WestCoast
    I 4got to add...........non/never have been/never will be....insured driving californians!
  11. Jan 12, 2008 at 5:52 PM
    dbbd1
    dbbd1 Well-Known Member
    A 2X8 works with just a little shaving on one edge. Here is what I did with my slots. (I do not carry most of my offroad gear with me all of the time, just the "important" stuff and the rest, which you see here, when I am 'wheeling).
  12. Jan 12, 2008 at 6:04 PM
    piercedtiger
    Jon
    Southern Tier, NY
    ^ looks good! So what's in the black box?
    You know you can't post the pic of an ambiguous black box and not list it's contents! :D
  13. Jan 12, 2008 at 8:49 PM
    dbbd1
    It is a Pelican case. At first I bought it because it is water- (and air-) tight. I found it very useful to hide the first wife's body until I could dispose of it properly. Now, it holds my power-puller, tow straps, duct tape, gloves, plastice tarp and such for off-roading (I can take some pic's tomorrow of the inside, when I am up in the hills).
  14. Jan 13, 2008 at 7:02 AM
    piercedtiger
    Jon
    Southern Tier, NY
    Nice! I was wondering if you could fit a body in it.... :D I need something like that for my extra off road gear. I just leave my hi-lift in 24x7 now, and my tow strap behind the rear seats. Once I get any more crap I'll need a box in the bed for it.
  15. Jan 13, 2008 at 10:12 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    I used some 1x8 composite deck material and it seems to line up pretty good. It's not Trex brand, but I did find it at Home Depot.
  16. Jan 13, 2008 at 6:41 PM
    dbbd1
  17. Jan 13, 2008 at 8:14 PM
    dbbd1
    Here is what it is used for now, wink wink, nod nod.
  18. Jan 14, 2008 at 7:33 AM
    piercedtiger
    Jon
    Southern Tier, NY
    looks good. So was it hard to get the blood off?
  19. Jan 14, 2008 at 8:47 AM
    sawdust
    sawdust Unapologetic Texan
    Frisco, TX
    07 TRD Offroad Radiant Red V6 Auto DC
    Homelink mirror, tailgate lock, 2ndary air filter removal, Access LE tonneau, Bugflector II, hitch-based bed extender, vent visors, suspension TSB, stall mat
    I did this last month the same time I got that hitch-based tailgate extender phantom posted. There's a thread on here about it. Search for "hauling plywood" to find it.
    You need a 2x8 if you want to fit the width of the slots. The slots are deeper than 1-by lumber would be. I notched the bottom of the lumber so the top would be flush. I nibbled it away with a miter saw set to the right depth.
    Also, that tailgate extender needs some mods before it's completely useful. It needs to be cut so it extends less if you want support for 8-foot lumber. I also have to add carpeted 2-by blocks on top of it (with hose clamps) so that in the top position it's level with those cross beams. It also needs a new lowest position hole if you want it level with the tailgate to support narrow lumber.
    I put in more effort than I really wanted to, but since I like make furniture, sometimes I'm hauling high-dollar hardwood veneered plywood.
  20. Jan 14, 2008 at 12:41 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
