Plastic Jerry Can help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Madjik_Man, Jun 9, 2012.
  1. Jun 9, 2012 at 8:20 AM
    Madjik_Man
    Madjik_Man [OP] The Rembrandt of Rattle Can
    Colorado Front Range
    I honestly have no idea what forum to post this in, so I just default to the coolest one :eek:
    I have two plastic jerry cans that have had gasoline in them for probably 9 years.
    I am wondering what do I need to do if I want to actually use them this summer, eg properly disposing of the gasoline currently in them and then cleaning? or treating? the jerry cans so I can properly store new gasoline.
    Thanks
  2. Jun 9, 2012 at 10:25 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Removable tanks, such as those that come with boat motors, motorcycles and lawn care equipment tend to be easier to clean. However, they usually hold gasoline mixed with oil and tend to be left sitting longer between uses, so cleaning them is essential. The tank should be removed from its moorings and drained of any fuel. The fuel itself should be strained through a thick cloth if one intends to use it again. Once empty, throw in a handful of screws, bolts and nuts as well as a quart of cleaning solvent. The best cleaning solvent to use is acetone, given its tendency to vaporize quickly. The metal will help to scour the insides of the tank free of anything that would stick. Seal the cap of the tank, and then shake it thoroughly before pouring out the solvent and metal. You may need to rinse out the tank with more clean solvent, repeating the process until the solvent comes out clear. Simply leave the tank--cap off--in a well ventilated area for a day. The solvent will have vaporized by then, leaving you with a clean tank.
    Read more: Cleaning the Inside of a Plastic Gas Tank | eHow.com http://www.ehow.com/how-does_4794946_cleaning-inside-plastic-gas-tank.html#ixzz1xJmA8HBI
    Seen ^^^^this on the net I have heard of doing this in cars with old gas tanks.
  3. Jun 10, 2012 at 9:36 AM
    Ninja
    Ninja The Lone Wolf of TW!
    Charles
    Arizona
    '04 Prerunner SR5 Reg. Cab
  4. Jun 11, 2012 at 11:19 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I have found that the closest storm sewer readily accepts gasoline, used oil, paint, batteries, tires, and anything else I can fit down it.
  5. Jun 11, 2012 at 11:24 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    Thank you for your continued pollution efforts :D
  6. Jun 11, 2012 at 11:50 AM
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    :smash:
  7. Jun 11, 2012 at 11:51 AM
    MowTaco
    Kansas
    You are quite welcome. Glad I'm not the only one that enjoys the pretty rainbow oil film on top of all my waterways!
  8. Jun 11, 2012 at 3:48 PM
    Madjik_Man
    Yeah, been there many times.
    I think I'll just trash these plastic ones and not deal with the really old gasoline. Then buy new metal ones and take care of them.
  9. Jun 11, 2012 at 7:45 PM
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    Take a trip to the gulf of Mexico. You'll love the water down there!
  10. Jun 12, 2012 at 2:50 PM
    Submariner
    Submariner Member
    Wayne
    Eagle Point, Or
    98 tacoma sr5
    air filter and custom headlights
    Go out the nearest national forest and find a pile that has not been burned yet, put them inside them as far as you can get them and touch them off. a forest fire fighter will thank you for new job opporturnities.
    Just kidding, take them to your nearest hazmat center and turn everything in to them
  11. Jun 12, 2012 at 3:01 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Ill buy those cans if you ars really interested in getting rid of them :cookiemonster:
  12. Jun 12, 2012 at 3:16 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Time for epic bone fire.
  13. Jun 12, 2012 at 3:30 PM
    Madjik_Man
    Can't tell if serious...
    That's what she said.
  14. Jun 12, 2012 at 3:40 PM
    Madjik_Man
    Not exactly sure I feel safe shipping jerry cans w/gasoline in them [​IMG]
  15. Jun 12, 2012 at 4:25 PM
    Madjik_Man
    They're plastic ones I bought about 10 years ago
    :notsure:
  16. Jun 14, 2012 at 9:51 AM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    Hello Jerry!
  17. Jun 14, 2012 at 1:11 PM
    MowTaco
    Kansas
    I actually am constantly on the lookout for those... garage sales, flea markets, etc. I hate the stupid spouts on the newer CARB compliant ones and end up spilling way more than would have evaporated or whatever the hell they were made to stop from happening.
  18. Jun 14, 2012 at 1:32 PM
    trmarshall1
    trmarshall1 The Least Interesting Man In The World
    Tim
    San Jose, CA
    02 Tacoma 4x4 TRD Supercharged
    4" Pro-Comp Lift, TRD cat back exhaust, grey wire mod, clutch pedal linear spring mod
    @ MadjikMan, properly dispose of the fuel and sell them. I need to find some old school metal ones for fuel and water...hmmm, looks like I gotta start hitting the flea markets again.
