Plastic Moulding under windshield!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hamtaco4x4, Dec 28, 2015.
  1. Dec 28, 2015 at 7:28 PM
    hamtaco4x4
    hamtaco4x4 [OP] Well-Known Member
    Collin
    Silver Spring, Maryland
    2009 V6 SPORT 4X4 4.0L
    Help! I punched a pretty decent sized hole in the plastic moulding underneath the windshield on the passenger side and I cant seem to find the part or part number to replace it. It is leaking water into the cabin of my truck and destroying my cabin airfilters. Part numbers, websites, or quick fixes would be greatly appreciated. Thanks!
  2. Dec 28, 2015 at 7:32 PM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    Pic would help.
    Maximus likes this.
  3. Dec 28, 2015 at 7:41 PM
    hamtaco4x4
    Collin
  4. Dec 28, 2015 at 7:41 PM
    hamtaco4x4
    Collin
    Im sorry its really tough to see but its the plastic directly under the windshield and directly over the cabin air intake.
  5. Dec 28, 2015 at 7:46 PM
    hamtaco4x4
    Collin
    Even just a quick patch to get me through the winter would help a ton.
  6. Dec 28, 2015 at 7:52 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Have you tried duct tape?
  7. Dec 28, 2015 at 7:53 PM
    hamtaco4x4
    Collin
    There is quite a bit of dirt and snow so im not sure if it would hold. I guess its worth a shot until I can get it to a shop.
  8. Dec 28, 2015 at 8:28 PM
    G.T.
    G.T.
    CONUS
    Collin, was the hole caused by that 90° elbow hitting it while it was frozen? If so, consider changing out to a Firestik brand "firering" cable that makes that union considerably shorter.
  9. Dec 28, 2015 at 9:04 PM
    hamtaco4x4
    Collin
    Yes unfortunately. When it was warm it had just barely enough clearance and now that its cold, I shut the hood and it punched a hole. How does the cable work? Would I just need a stud mount? Im using a firestick 3' antenna with a medium duty spring and a relentless hood mount. Thanks!
  10. Dec 28, 2015 at 9:07 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Firering -
  11. Dec 28, 2015 at 9:08 PM
    ramonortiz55
    Ramon
    Texas
    stock
    Yes you can replace that plastic part.
  12. Dec 28, 2015 at 9:10 PM
    hamtaco4x4
    Collin
    Maybe I should have done a little more research before installing my CB radio :/ Thank you sooo much for your help!
