Plastic removal
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dirt clod, Jul 31, 2025 at 8:19 AM.
  1. Jul 31, 2025 at 8:19 AM
    dirt clod
    dirt clod [OP] Active Member
    Greg
    2023 Tacoma
    I will be adding a Redarc and also another switch. Using a pry tool, does this whole assembly come out?
  2. Jul 31, 2025 at 8:21 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I found it difficult to get that panel out of there….I ended up pulling the trim off of the dash a bit and then pushing the smaller trim out from behind. That was easier.
  3. Jul 31, 2025 at 8:38 AM
    AZPhys13
    AZPhys13 Well-Known Member
    2021 TRD OR DCLB - MGM
    A plastic trim tool will do the trick. I think the last time I had it off I used a skinny tool with a little lip that clicked in behind the panel. It ended up being more of a pull than a pry.
    dirt clod[OP] likes this.
  4. Jul 31, 2025 at 8:46 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I was unaware that the panel pried out. Its much easier to pull the lower dash assembly.
    dirt clod[OP] and jmneill like this.
  5. Jul 31, 2025 at 9:09 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Jakerou, dirt clod[OP] and Danner488 like this.
  6. Jul 31, 2025 at 9:29 AM
    Danner488
    Danner488 Well-Known Member
    2016 TRD Sport
  7. Jul 31, 2025 at 11:10 AM
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    Woah. i use a pocket knife and pry from the upper side and it pops right out
    Danner488 and dirt clod[OP] like this.
  8. Jul 31, 2025 at 3:15 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Yay for the good ole pocket knife.
    Good for everything except bolts.
  9. Jul 31, 2025 at 6:04 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    I remove mine regularly. The best pry point for me is the left-hand side mid-way where the levels change and the edge is most accessible. Pops right out with a bit of force. Don't bother with the Redarc video unless you wish to get further into the vehicle guts. Use a plastic tool, not a knife.
  10. Jul 31, 2025 at 6:33 PM
    wake100
    Syracuse, NY
    Even though I use a knife, I’ve taken mine out a few times, if new to removing it I would recommend the plastic tool though
    Willy Lump Lump likes this.
  11. Jul 31, 2025 at 6:36 PM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    Yeah but you’re from the cuse though. People from upstate tend to get things done, and then look at it later.
  12. Jul 31, 2025 at 6:37 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Prying with a knife always has risks. Plastic pry tool.
  13. Aug 1, 2025 at 6:32 AM
    jmneill
    SE
    The OP is mounting a Redarc controller...
  14. Aug 1, 2025 at 7:20 AM
    Willy Lump Lump
    21’ dcsbmt
    This and that
    Isn’t it just plug it in, secure box, run wire for controller?
  15. Aug 1, 2025 at 7:23 AM
    jmneill
    SE
    Yep, but you need more access under the dash to mount the controller than popping the little panel alone provides.
  16. Aug 1, 2025 at 7:26 AM
    Willy Lump Lump
    21’ dcsbmt
    This and that
    Well if you pop it from the back, you’ve removed the sill, kickplate, and knee thing.
  17. Aug 1, 2025 at 7:28 AM
    jmneill
    SE
    yea, it's quick and easy.
    A minute to pull it all, and a few to re-assemble.
  18. Aug 1, 2025 at 7:41 AM
    Willy Lump Lump
    21’ dcsbmt
    This and that
    I think it takes longer to actually find the YouTube vid (couple of ads) than just doing it.
    jmneill[QUOTED] likes this.
  19. Aug 1, 2025 at 9:38 AM
    Toycoma2021
    The OP's question was how to remove the switch panel; his post did not ask the rest of the question on how to install the controller. One of the original videos (it seems one video has been removed, IIRC) showed using a knife to do so - that was in my opinion moronic of a company to have in a video. Too easy to slip up and do damage. Sorry if I did not make it clear I was in complete opposition to using a knife to do so.
    My original statement which you choose to "selectively" quote:
    "Don't bother with the Redarc video unless you wish to get further into the vehicle guts."
    Yes, the remaining Redarc video would be helpful when he actually does the controller install. For removing the switch panel not so much.
    The OP also references installing another switch. We don't know if he will do both operations at the same time. I choose to answer his question only.
  20. Aug 1, 2025 at 9:46 AM
    jmneill
    SE
    OP will NEED to get further into the dash to mount the Redarc, whether he knew it or not...
