Plastic vs aluminum boat fuel tank
Discussion in 'Boating & Fishing' started by TacomaJunkie8691, Dec 6, 2020.
  1. Dec 6, 2020 at 1:02 PM
    TacomaJunkie8691
    TacomaJunkie8691 [OP] 1999WineTacoma
    WA State
    1999 Wine Tacoma SR5 Exta-Cab 4wd V6
    Completely Stock except for Ranch 5000 Shocks and Struts.
    Dear Fellow Tacoma Junkies and Hard Core Addicts,
    How is everybody doing on this Sunday? Sorry for this request not being first generation Tacoma related. It is just that this site is much more helpful than the Boston Whaler sites.
    My family and I are trying to design a fuel tank for little 1984 Boston Whaler Classic Sport 15. We would like to know the advantages and disadvantages of both plastic and aluminum.
    Thank you in advance for all of your replies.
    Take care,
    Paul
  2. Dec 6, 2020 at 1:04 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    im not quite sure if this is applicable to a Toyota truck site
  3. Dec 6, 2020 at 1:14 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  4. Dec 6, 2020 at 3:17 PM
    My Name is Rahl
    The only thing you'll have to worry about with an aluminum tank is metal galling from dissimilar metal contact. If you go plastic, you could design it so all the fasteners are 316 stainless steel. That would take care of any rust issues you might have.
    TacomaJunkie8691[OP] likes this.
  5. Dec 6, 2020 at 9:30 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Stainless steel all the way. My 1977 Bayliner had the steel tank replaced with a stainless one in the 90’s and it’s still holding up.
  6. Jan 5, 2021 at 9:04 AM
    StockerWithALocker
    StockerWithALocker Well-Known Member
    Earf.
    2009 DCSBTRDO
    3" Belltech lowering spindles, notched frame, 20" Boyds wheels, chrome steering wheel, dump bed.
    For what it's worth- I have two 15 gallon aluminum tanks on my boat. Zero issues, just keep an eye on your fasteners(sending unit bolts, etc). Plastic tanks seem to have a short lifespan, from what I've seen.
  7. Jan 5, 2021 at 9:12 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Check Defender for many inexpensive plastic tank sizes. Will it be in/underneath a fiberglass covering or cubby? If not then go steel.
    As someone that had aluminum tanks deteriorate and shait 30 gallons of blackwater into the bilge I'd say go plastic. Dry heaving while shop vacuuming poop juice is not a good time.
  8. Jan 5, 2021 at 9:13 AM
    StockerWithALocker
    Earf.
    2009 DCSBTRDO
    Oooooooooof.....
  9. Feb 24, 2021 at 3:54 PM
    mattys010
    mattys010 Well-Known Member
    2010 DCLB TRD Sport
    If it sits on the the deck, the red poly portable tanks are hard to beat. If it’s under the dec there are a lot of things to consider. post some pics
