Plate bumper/Lift question.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Genghis_Khan60, Aug 24, 2021.
  1. Aug 24, 2021 at 1:23 PM
    Genghis_Khan60
    Genghis_Khan60 [OP] Active Member
    Hamza
    Booneville, MS
    2015 Blue Ribbon Tacoma TRD OffRoad
    Howdy Tacoma World!
    I’ve been tossing around the idea of mounting a plate bumper to my Tacoma strictly on the basis of adding a winch for what little off-roading I do and some front end protection. I don’t go down trails or take my truck through ORV parks. I mainly use it around my farm and occasionally pull folks here and there on the hunting club.
    From what I have seen, most everyone uses the 3” OME lift with the heavy rated springs to carry the weight. However, is it possible to mount a plate bumper, keep my stock ride height, and not have the nose of my truck dragging the dirt?
  2. Aug 24, 2021 at 3:21 PM
    VXEric
    VXEric Well-Known Member
    Eric
    Worcester, PA
    07 ACS V6 6 Spd TRD Sport
    265/70/17 ATs on 17x8"wheels and 0 offset Morimoto XB LED Fogs Reinforced tailgate 2011 Honeycomb grille URD Short Shifter and cue- ball style knob
    I went with a pretty minimal bumper setup and a 10k lb winch because my use is pretty much exactly what you describe. With a 70 lb bumper and an 80 lb winch the front end is dipped notably. I went with a set of toytec 620lb springs with bilstein 5100s on the lowest setting. From what they told me when I purchased I should see about 1" of lift in the front (from original stock height) which will really just level me out and help manage the extra weight.
    Unfortunately I haven't installed yet so I can't tell you how well it worked.
  3. Aug 24, 2021 at 5:01 PM
    huyner
    huyner CoCKaSiAn
    Huy
    Orlando
    2007 Tacoma TRD Prerunner Sport 4x4
    a lotta money spent, lotta scars made
    they make aluminum bumpers now or go with a prerunner style
