Plate Bumpers after impact with pics?
Discussion in 'Armor' started by ManBeast, Jun 28, 2015.
Favorite brand.
  1. Pelfreybilt
    116 vote(s)
    17.9%
  2. Sos concepts
    55 vote(s)
    8.5%
  3. Allpro
    10 vote(s)
    1.5%
  4. Demello
    38 vote(s)
    5.9%
  5. Bruteforce
    36 vote(s)
    5.6%
  6. ARB
    179 vote(s)
    27.6%
  7. CBI
    48 vote(s)
    7.4%
  8. Relentless
    57 vote(s)
    8.8%
  9. C4
    28 vote(s)
    4.3%
  10. Road Armor
    6 vote(s)
    0.9%
  11. Mobtown
    28 vote(s)
    4.3%
  12. FabFours
    14 vote(s)
    2.2%
  13. RCI
    10 vote(s)
    1.5%
  14. Tyger
    1 vote(s)
    0.2%
  15. Steelcraft
    1 vote(s)
    0.2%
  16. Victory 4x4
    10 vote(s)
    1.5%
  17. Westin
    0 vote(s)
    0.0%
  18. Go Rhino
    2 vote(s)
    0.3%
  19. Shrockworks
    8 vote(s)
    1.2%
  20. Hefty Fabworks
    1 vote(s)
    0.2%
  1. Oct 24, 2022 at 7:56 PM
    #881
    la0d0g
    running for the hills
    For crawling not hauling
    What bumper is that?
  2. Oct 25, 2022 at 8:25 AM
    #882
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    ... and how do you like those Kendas?
  3. Oct 25, 2022 at 9:34 AM
    #883
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Coastal Offroad extreme clearance
    I brag about them all the time, my 2nd set of them and they havent skipped a beat, and I also beat the crap out of them like the bumper haha.
  4. Nov 14, 2022 at 4:48 AM
    #884
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    I like the vertical mounts, but not all the square holes, as they tend to focus stress, even with rounded corners.
  5. Jan 3, 2023 at 8:10 PM
    #885
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    How did you color-match your ARB bumper? Did you special-order it from ARB that way?
    Or did you sand/bead-blast the entire thing down to bare metal & repaint it yourself?
  6. Jan 3, 2023 at 9:47 PM
    #886
    GilbertOz
    GilbertOz Driver
    CA
    Need to add BAMF (Bay Area Metal Fabrication) bumpers to the poll. All of BAMF's stuff is top-tier.
    https://www.bayareametalfab.com/Toyota_c_38.html
    Separately: are there any TW threads focusing on damage prevention or mitigation from heavy-duty bolt on or weld-on sliders? I imagine those might to quite a ways towards mitigating side impact damage as they transfer load directly & broadly across a large area of frame.
  7. Jan 4, 2023 at 4:39 AM
    #887
    Fifthwind
    Murph
    Lehigh Valley, PA
    Scully
    I received it powder coated black. Roughed it with scotchbrite(?) type pads, and 3m prep wipes, spray balled it with dupli-color, about six cans IIRC, then about the same amount of clear coat. Did it outside under a canopy. Came out way better than expected. I did take my time which probably helped a lot, as I used an engine hoist and straps to save my toes.
  8. Jan 4, 2023 at 4:41 AM
    #888
    Fifthwind
    Murph
    Lehigh Valley, PA
    Scully
  9. Jan 4, 2023 at 6:55 AM
    #889
    CowboyTaco
    North Georgia
    11 TRD Sport
    I may have to do the same with mine. The black powerdercoat has faded terribly. I was able to polish it some. I only did one section to see how it did compared to the rest and I think a good polish all over may be warranted. If that doesn't work, I may pull it off and repaint it. I'll probably stick with black though.
  10. Jan 4, 2023 at 3:08 PM
    #890
    GilbertOz
    GilbertOz Driver
    CA
    Interesting, very interesting.
    When I got my ARB brand-new, in black powdercoat of course, first thing I did was alcohol-wipe a hidden section underneath, let the alco evap away completely, & then test-paint it with some yellow Rustoleum "plastic-compatible" rattle can paint.. Or maybe it was Krylon Fusion. Definitely not DupliColor.
    Coated fine, dried fine, but chipped off easily with a fingernail 24 hours later.
    How long have you had your DIY paint job on there and how is it holding up? Also what kind of 3M prep wipes, exactly? Are they based on a common solvent like acetone that I could just do straight out of a bulk can & rag, or a hand pump spray bottle?
    Your paint job looks excellent.
    Fifthwind[QUOTED] likes this.
  11. Jan 5, 2023 at 9:53 AM
    #891
    Fifthwind
    Murph
    Lehigh Valley, PA
    Scully
    Thanks, I think that the weather during the process helped a lot; dry and warm for this part of the country.
    I found the prep wipes on Amazon, and it appears that they are Dupli-Color wipes, and not 3M.
    https://amazon.com/gp/product/B00B36EI1M
    I painted and installed back in 2014, and, aside from bumping a few trees and boulders while crawling in central PA, the paint is holding up better than factory, as I will be getting the hood repainted soon. I think that I used more clear coat than factory.
    I painted it, and let it sit for days, under the canopy in the summer sun, as I wanted the clear coat very hard before using the hoist.
    GilbertOz[QUOTED] and CowboyTaco like this.
  12. Jan 19, 2023 at 4:40 PM
    #892
    lit_taco4x4
    lit_taco4x4 IG and YT: @2a_crawlcamper
    Louie
    2018 Tacoma TRD Pro
    JD fab LT, Archive and Deavers, King shocks, Dual locked, Dual T case, Tundra steering rack, 39’s
    I second this. They have Tyger? Thing looks like trash.
    Spankomatik likes this.
  13. Mar 18, 2023 at 11:16 PM
    #893
    SagWagon
    SagWagon Well-Known Member
    Geoff
    Portland, OR
    2022 TRD OR
    Apogee Offroad bumper. I has cruise set for the speed limit at 45. Cops think the drunk that hit me was doing 90.
  14. Mar 19, 2023 at 1:55 PM
    #894
    GilbertOz
    GilbertOz Driver
    CA
    All things considered that looks like a very good result. Without that bumper the rear half of your truck probably would've accordioned up halfway to the back of your cab. Hope you're OK & didn't suffer any major injury such as whiplash.
    Also looked like your $5K-$8K (?) super-nice camper shell was absolutely untouched.
    How were the frame rails after that? Any bending or distortion?
    Borealis, CowboyTaco and Tatts521 like this.
  15. Mar 19, 2023 at 2:53 PM
    #895
    SagWagon
    Geoff
    Portland, OR
    2022 TRD OR
    We definitely have injuries. Aches and pains are still popping up, and I never realized before how bad concussion can be.
    The camper survived, amazingly well! Everything is square and working exactly the way it should be.
    The frame was all twisted up to the point. It wasn’t even repairable. The damage is way worse than the picture shows. It’s hard to tell, but the hitch ball is pointing straight down to the ground. The truck was totaled.
    I completely agree with you. I feel like that bumper saved us from significantly worse problems
    Yetimetchkangmi and Tatts521 like this.
  16. Mar 19, 2023 at 3:18 PM
    #896
    PilotBoy352
    PilotBoy352 Well-Known Member
    Tim
    Mesa, AZ
    2015 MGM DCSB (rip) now 2018 white DCSB TRDOR 6MT
    Here's my truck on Christmas Eve 2021 less than a week after I put my Victory 4x4 Blitz bumper. Lady in the HOV lane hit a puddle and lost control and swerved over and hit my front end in the far right lane. I definitely kicked myself for not getting a full bumper, but I got the truck back and everything is fine now.
  17. Mar 19, 2023 at 3:58 PM
    #897
    GilbertOz
    GilbertOz Driver
    CA
    Sorry to hear that, both on the injuries & the frame. If you have any photos of the frame damage, please consider posting/sharing. I'd be interested to see what happened/how it was damaged.
    Tatts521 likes this.
  18. May 2, 2023 at 3:58 AM
    #898
    Nomad426
    Nomad426 Well-Known Member
    Austin
    South West Houston Tx
    2019 Trd Off Road
    Ome Lift, Icon Leafs, Safari Snorkel, Bronze trd 4frunner wheels
  19. May 11, 2023 at 11:50 AM
    #899
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    Crash with a Honda gold wing
    POOLGUY and BYJOSHCOOK like this.
  20. Jul 19, 2023 at 1:32 AM
    #900
    TacoTuesday1
    SD CA
    thats not a bumper
    TS4x4 likes this.
