Plate carrier questions
Discussion in 'Guns & Hunting' started by UhOhSpaghettios, Aug 7, 2022.
  1. Aug 7, 2022 at 8:30 PM
    UhOhSpaghettios
    UhOhSpaghettios [OP] Very unprofessional sender
    NC
    2016 SR5 ACLB
    3” Toytec lift 16x9 Method 305 285/75-16 Toyo AT3 Custom exhaust Custom retrofits
    Hey you wonderful peeps, I’m going to start saving up for a plate carrier, and wanted to get some opinions on what setup to run. I’m looking at (1) a Frankenstein build with a T.Rex AC1 paired with some Hailey and Spiritus things, (2) a Crye JPC for a slimmer, more light weight setup, or (3) a Haley thorax kit. The Haley kit is right at the edge of my budget after everything I’d add so it’s my least favorite of the three. I’m also very open to other suggestions on different brands and combos. Thanks!
  2. Aug 7, 2022 at 8:34 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    :popcorn:
    wilcam47 likes this.
  3. Aug 8, 2022 at 8:38 AM
    MadRussian
    MadRussian Well-Known Member
    Metrowest MA
    2010 TRD OR AC
    Main question is how do you plan to use it?
    The AC1 (and other Low Viz carriers) have the elastic sides that double as mag pouches, benefit is you can move mags off the front to the sides for a more discrete fit, draw back is there is little else you can use the sides for. Crye and Haley IMO are designed to be more loaded up with side molle and back panels.
  4. Aug 8, 2022 at 8:56 AM
    Redhead fishin
    Redhead fishin Well-Known Member
    If your neighborhood is that bad, I’d spend the $ on a technical.
  5. Aug 8, 2022 at 5:31 PM
    UhOhSpaghettios
    NC
    2016 SR5 ACLB
    I live in the suburbs and have a bug out spot in the mountains, so it would need to be able to hold a decent amount of gear but I want to be able to take it off if I need to scramble around in the mountains. Being able to go slick and discreet would be nice but not necessary
  6. Aug 9, 2022 at 7:30 AM
    MadRussian
    Metrowest MA
    2010 TRD OR AC
    Looks like JPC has a built in 3-mag front pouch. If you don't want three mags across the front, then get the Haley with just a molle panel and arrange what ever pouches you want.
    I suggest spending a whole day doing stuff around the house with the PC on and shooting at the range from a vtac wall or something similar. It will show you where the points off discomfort are.
    Speedbird likes this.
  7. Aug 9, 2022 at 11:51 AM
    DEDAFLO670
    DEDAFLO670 Well-Known Member
    Manuel
    Waipio
    15 Trd sport
    First spear, the tube systems cummerbund is a game changer with plate carriers.
  8. Sep 3, 2022 at 11:48 AM
    p1smo
    p1smo Well-Known Member
    2003 Tacoma TRD 4x4 3.4L 5MT
    Relentless Stealth front + Relentless standard rear plate bumpers w/ D2 cutouts, 2x Rigid D2 floods front + 2x Rigid flush D2 floods rear, BAMF behind-the-grille light bar mount w/ 2x Rigid 6" bar floods, KING coilovers/springs + rear adjuster shocks, Deaver leaf springs, Total Chaos UCAs, BAMF rock sliders, BAMF LCA skids, Relentless front skid, Low-Range Off-Road gas tank skid, Marlin differential plate cover, Marlin E-Locker motor guard, Hawke HD brake pads, Trail Gear steel brake line kit, Marlin HD full clutch assembly, deckplate intake mod + AFE high flow filter, ARB CKMA12, exhaust dumped over rear axle, 32/11.5r15 Cooper Discoverer AT3 XLT, American Racing Baja 15x8, Viper alarm + fuel cutoff switch, and more Toyota OEM parts + replacements than I care to list
    I'd pass on the T.Rex PC and check out Defense Mechanisms instead. Just be aware that their PCs are pretty minimalist and run VERY true to plate size, so order accordingly. My other PCs are Velocity Systems with Haley add-ons and I love them because they fit so well, even if they're a tad outdated on their designs. All the companies you're listing are quality though, so you shouldn't have any issue.
