Play god with my truck lift
Discussion in 'Suspension' started by Claytor, Aug 11, 2010.
  1. Aug 11, 2010 at 2:44 PM
    Claytor
    Claytor [OP] Well-Known Member
    Clayton
    TX
    SR5 4X4 TRD OR
    Full OME Lift W/top spacers, Dakars in the rear, extended rear brakelines, CHROME Satoshi, 17x8 American Racing Mojave Teflons, Nitto 295/70/R17 Trail Grapplers
    Alright, in the next few months I want to lift my truck.....I'm a first time tacoma owner :D and new to the world of off roading....
    So.. If you were me and had a stock 2010 TRD off road 4x4 double cab... what would you do to lift your truck? I want more than three inches but less than 6. I know the higher you go the more stuff you gotta do, extend brake lines stuff with gears so on....
    point me in the right direction, help control my trucks fate!!!
    THX
  2. Aug 11, 2010 at 2:46 PM
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
    I would go with a suspension lift between 3" and 6". Front and rear. Probably from a company. Hope this helps...
  3. Aug 11, 2010 at 2:49 PM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    solus694 has a 4.5" rcd lift. it looks really good
  4. Aug 11, 2010 at 2:50 PM
    stroM-
    stroM- @alteregoadventure
    Santa Rosa, California
    2006 4X4 TRD OR
  5. Aug 11, 2010 at 2:55 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    long travel I like allpro's system because you can run it with stock fenders. Custom rear suspension 4 link with airbags and in cab controller
  6. Aug 11, 2010 at 8:09 PM
    Claytor
    Clayton
    TX
    SR5 4X4 TRD OR
    its funny you should say that because I noticed his truck a month or two back and its exactly what the type of setup Im going for... only thing holding me back is that installing the RCD requires some cutting of the frame doesnt it? As a noob to all this I dont know if I want to go that far down the rabbit hole just yet haha.
    I was thinking something along the lines of Toytec's Ultimate lift... and maybe throwing something else in with it to get that extra inch or so.....
    how much is that RCD go for? i didnt see a price on the site.
  7. Aug 11, 2010 at 8:56 PM
    borderbrat
    Jeremy
    Victoria BC, Canada
    can't do that with a 4x4 not if you want to keep your front cv joints for any period of time. to get more than 2.5" of lift you either need to do a drop bracket like RCD procomp fabtech all which require cutting the front cross-member or long travel allpro camburg to name a couple these require new upper and lower control arms as well as shocks and longer front axels. Long travel will push the front wheels out further.
  8. Aug 11, 2010 at 9:03 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    OME 3". you can pick it up from toyteclifts.com with a discount from this forum
  9. Aug 11, 2010 at 9:08 PM
    113tac
    Stephen
    Northern Virginia
    im not exactly sure how much it cost...sorry but yeah i know what you mean
    i think the toytec would be good. the all pro long travel is pretty sick too...just search for toytec lifts on here and pm solus and see what he says about his lift and you should get plenty of info
  10. Aug 11, 2010 at 9:25 PM
    Claytor
    Clayton
    TX
    SR5 4X4 TRD OR
    I hear what you are saying, but care to explain it a little more? :D
    could have sworn ive seen lots of guys with 4x4s with the ult toyec..
  11. Aug 12, 2010 at 12:40 PM
    113tac
    Stephen
    Northern Virginia
    i didnt think you had to cut for the crossmember for the small dropbracket(non rcd procomp fabtech)...but dont quote me on that considering i only have a 2wd haha
  12. Aug 12, 2010 at 12:52 PM
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    rcd ftw!!!!
  13. Aug 12, 2010 at 12:54 PM
    borderbrat
    Jeremy
    Victoria BC, Canada
    adding to the toytec ultimate lift to get an additional inch of lift totaling approx 4" is what I was talking about with regards to CV angles
  14. Aug 12, 2010 at 6:51 PM
    CopDoctor
    08 335i
    yea you'll screw everything up with 4" and no UCAs or diff drop
  15. Aug 12, 2010 at 6:56 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    I will smite you downnn
  16. Aug 12, 2010 at 9:37 PM
    Claytor
    Clayton
    TX
    SR5 4X4 TRD OR
    :rolleyes: alright this is getting in over my head......
    Im going to simplify my question.... what and where is a good place to start with lifting my truck.... something I can do now and maybe after some time and more money I can expand on. (Im going to head this of now)Im thinking I can do somthing more advanced than spacers.
    I think i gist of what yall are saying about adding too.. but What about the ult toytec just by itself?
  17. Aug 12, 2010 at 9:39 PM
    borderbrat
    Jeremy
    Victoria BC, Canada
    if you want over 3" either 4x4 compatible long travel (Allpro, Camburg...) or drop bracket lift (rcd, procomp, fabtech)
  18. Aug 12, 2010 at 9:40 PM
    menyh
    menyh Well-Known Member
    Meny
    LA
    09 Prerunner
    6'' Procomp Stage I lift
    6 inch lift
  19. Aug 13, 2010 at 9:26 PM
    113tac
    Stephen
    Northern Virginia
    the next step above spacers would probably be 5100s in the front and aal in the back or nothing in the back...but 5100s only give 2.5" of lift.
    but i believe the toytec ultimate lift gives you everything you will need for the amount of lift you would get except UCAs if i read the list of include parts correctly.
  20. Aug 13, 2010 at 9:32 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    IMO drop brackets are not the way to go for offroading. For looks yes, but I much rather go for 3" like the ome system. a 3" lift makes an awesome offroad vehicle. next best thing is SAS. Allpro LT is awesome too. I here 4" or more of lift with no drop brackets. really pricey though.
