Play in between left front wheel and rack & pinion... 2000 PreRunner
Discussion in '1st Gen. Tacomas (1995-2004)' started by rzgkane, Sep 9, 2015.
  1. Dec 3, 2016 at 9:44 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Really hard to say from here, in theory a definate "maybe". You may need an alignment now or did before the slop developed and there are a lot of other "if's". The slop allowed by a worn guide will allow for fluctuation in toe values. It all depends on how things settle with the new goods. New bushings can also affect toe numbers.
    The driver side toe value will be the most affected by the guide while bushings will affect both sides.
    AND there is no such thing as "rack guide clearance", much less a spec for it.
  2. Dec 3, 2016 at 9:59 AM
    skeezix
    skeezix Ol' Geezer
    Western Slope of Colorado
    1998 Limited
    Absolutely.
