Play in CV joints?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NHCrewcab2008, May 7, 2012.
  1. May 7, 2012 at 5:16 PM
    NHCrewcab2008
    NHCrewcab2008 [OP] Well-Known Member
    Thornton, NH
    SR5 TRD
    Called the dealer today and asked if there is suppossed to be a little play in the CV joints of a 2nd gen taco and they said yes, is this true?
  2. May 7, 2012 at 5:17 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Normal, especially the driver's side.
  3. May 7, 2012 at 8:01 PM
    double09
    double09 Member
    Jacksonville IL
    2009 Double Cab LB TRD Package
    Side windows tinted, 8 in windshield strip, remote start, head lights
    I had the same concern but also had 2 torn cv boots. having the platinum warranty and having to get a little stern I got both cv shafts replaced for free!
  4. May 7, 2012 at 8:09 PM
    jandrews
    '09 FourDubDee TRD OR
    1/4" or so of slop is normal.
  5. May 7, 2012 at 10:28 PM
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    Yes. It is normal. It is just the way the bearings and cups are designed inside the booots of the CV axles. Due to higher articulation of suspension in 4x4's, it is generally the case in most manufactures. Those who don't, have CV shafts wear out faster. You will generally only see guys replacing cv shafts if the boot has torn and the shaft has worn out due to lack of grease.
  6. May 8, 2012 at 1:05 AM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    Normal
  7. May 9, 2012 at 6:53 PM
    NHCrewcab2008
    Thornton, NH
    SR5 TRD
    Thanks for the replies. I have a small wobble in the front left wheel and can't figure it out and can't get back to dealer anytime soon and my warranty runs out in 4k miles.
  8. May 9, 2012 at 8:28 PM
    Ryanv
    Ryanv Toyota Technician
    15 4Runner
    Is the wobble when you jack the wheel up and move the wheel up and down and side to side if so its most likely a wheel bearing
  9. May 10, 2012 at 9:32 AM
    NHCrewcab2008
    Thornton, NH
    SR5 TRD
    Its a side to side wobble, and I had originally thought it was the wheel bearing, but the dealership told me it was fine. I feel like I am being screwed because my warranty is almost up.
