Play in Drive Shaft
Discussion in 'Technical Chat' started by lacroix86, Aug 13, 2013.
  1. Aug 13, 2013 at 4:48 PM
    lacroix86
    lacroix86 [OP] Member
    Hello ...I'm new to the forum and need some advice from knowledgeable folk.
    I have a 2005 Tacoma 2 wheel drive w/ manual transmission. Just had two new tires mounted up front w/ an alignment. I'm getting a heck of a vibration while accelerating in 2nd and 3rd. My mechanic tested it and said it felt like a universal joint on the drive shaft might have loosened. I got underneath it tonight and it seems to me the only play is up where the shaft goes into the block. Does that sound like it may be the problem and is it repairable?
  2. Aug 14, 2013 at 8:26 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    If the vibration started only after the new tires were mounted, I would blame them. They may need to be re-balanced, or are defective (out-of-round?).
    Also, check the tightness of the front lug-nuts.
  3. Aug 14, 2013 at 8:39 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If there is play across any of the universals, you should get them replaced. Where the shaft comes out of the transmission (or transfer case if you have a 4x4), there is a universal joint that connects the shaft to the output flange. If that universal has play, it can be replaced. The u-joint should be about $20 and the labor shouldn't be terrible or just do it yourself.
  4. Aug 14, 2013 at 9:31 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    A ball joint press' "c-clamp" is the right size to do our u-joints. Be very careful to not mangle a needle bearing as you reassemble.
